map sensor question?
Old Oct 6, 2003 | 07:37 AM
kell211's Avatar
Default map sensor question?
i'm getting a map cel whenever i got above 5500 rpm's (roughly). i have a turbo ls/vtec and i first thought it was my stock map sensor that was causing this because of the high boost, but now i'm not sure. i turned the boost down to 6psi and it still threw the code. the code goes off when you reset the ecu. what are the possible causes for this?
Old Oct 6, 2003 | 07:41 AM
mmuller's Avatar
Mad Scientist
Default Re: map sensor question? (kell211)
what kind of engine management?check valves?
Old Oct 6, 2003 | 07:45 AM
kell211's Avatar
Default Re: map sensor question? (mmuller)
greddy e-manage and profec e-01
Old Oct 6, 2003 | 07:55 AM
mmuller's Avatar
Mad Scientist
reset the ecu, and if not, test the map sensor
Old Oct 6, 2003 | 07:26 PM
kell211's Avatar
bump
Old Oct 7, 2003 | 05:39 PM
kell211's Avatar
what would cause a map sensor cel, other than pushing boost beyond it's capability to read?? and if the sensor was bad, wouldn't the cel come on the whole time, not just during high rpm's??
hondalove414
Mar 20, 2011 08:11 AM
kell211
Oct 8, 2003 07:00 PM
lysergican
Jul 12, 2002 04:29 AM
HybridCoupe
Jul 1, 2002 09:55 AM
