NO POWER TO RADIO AND CLOCK????????
I am not sure what else isnt working but the radio dosnt work at all and the clock has no power when the car is off because every time i start the car it is is reset. does anyone have any ideas why it might be doing this????
I assume its an aftermarket radio , if iti s then someone installed the contant and the ignition power wires or whatever source they tapped into for a constant either the fuse is blown or its not really a constant
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOAZZ94 »</TD></TR><TR><TD CLASS="quote">there was a fuse that was blown under the hood. it was the back-up fuse??????</TD></TR></TABLE>
replace it, and check to see if it blows again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOAZZ94 »</TD></TR><TR><TD CLASS="quote">it didnt blow again but when i put the fuse in it kinda arked alittle. just alittle blue spark.</TD></TR></TABLE>
arked???
a blue spark on contact with the fuse = should be a.o.k.
arked???
it should be your constant, you're head unit has 2 power wires, one is ignition and the other is constant, if you can power up then it is the constant... either fuse or wire harness is damaged.
i had this same exact problem, but my car keeps blowing the fuse so i just ran a a new constant power wire for my clock, radio, and cig lighter
Nisif
Aug 28, 2008 10:29 AM
rukawa1one
Feb 18, 2005 04:31 PM
