Whats wrong with my stereo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">It's probably not the radio. Check your constant power wire and the fuse under the hood. </TD></TR></TABLE>God, i dont know **** about audio... what is a constant power wire? And which fuse would it be? Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> If we are talking about a g3 it's the 7.5A "backup" fuse in under hood fuse box, if it's a g2 it's fuse 14 -15A in under dash fuse box.
94 </TD></TR></TABLE>Thanks for your help, ill check that and see if that was it? Someone once told me it was a hotwire? What the hell is that? Or were they full of ****?
The constant wire is the one that always has power, wether your cd player is on or not (obviously so it can keep all of its presets and programs). It should be the yellow wire on the back of the receiver, not the red one. Make sure all of them are hooked up correctly and def. do what was said about checkin the fuses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 GSR »</TD></TR><TR><TD CLASS="quote">Thanks for your help, ill check that and see if that was it? Someone once told me it was a hotwire? What the hell is that? Or were they full of ****?</TD></TR></TABLE> Probably referring to the "HAAT" [hot at all times] wire, in the radio harness there are 3 wires the have 12V+ on them the white/blue, [HAAT] yellow/red, [hot in acc. or on] and the red/black, [hot when park lights on].
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmwright14 »</TD></TR><TR><TD CLASS="quote">The constant wire is the one that always has power, wether your cd player is on or not (obviously so it can keep all of its presets and programs). It should be the yellow wire on the back of the receiver, not the red one. Make sure all of them are hooked up correctly and def. do what was said about checkin the fuses.</TD></TR></TABLE> You mean has power whether ign. is on or not.
94
94
madcrossover
Jul 27, 2005 07:41 PM
SLOAZZ95
Oct 6, 2003 09:32 PM
