codes codes codes codes codes codes codes codes codes codes!!!!!11
Old Oct 6, 2003 | 12:22 AM
tegasaurus's Avatar
Default codes codes codes codes codes codes codes codes codes codes!!!!!11
I put in my fully built b18b, now awaiting turbo, and i was throwing code 14, no big deal - i got a new IACV and the code went away.
Now im throwing code 15 and code 20.
Code 15 = Ignition Output Signal missing or defective ignition output signal
Code 20 = Electrical Load Detector defective circuit or unplugged / defective sensor
common now... i fix 1 thing and 2 other break. What could be throwing those codes?
Also, FYI, when the car is no longer in "load" (eg: me giving it gas), it dies
Old Oct 6, 2003 | 12:47 AM
tegasaurus's Avatar
Default Re: codes codes codes codes codes codes codes codes codes codes!!!!!11 (tegasaurus)
update: i messed around with the ELS (electrical load sensor) and now it no longer displayes codes 15 and 20.... but now its back to the code 14 (IACV)... i just replaced it, wtf?
i think im gonna replace the plug, think that could be it?
Old Oct 6, 2003 | 10:59 AM
tegasaurus's Avatar
thanks...
Old Oct 6, 2003 | 11:28 AM
Mr. Softee's Avatar
ryan make sure you have the clips in the right sensors... sounds stupid but it could be the problem. the clips for some of the sensors are the same.
sam
Old Oct 6, 2003 | 11:35 AM
Mr. Softee's Avatar
Default Re: codes codes codes codes codes codes codes codes codes codes!!!!!11 (94goldjungsr)
also code 15 should be from the blue wire on the dizzy
Old Oct 6, 2003 | 11:37 AM
Mr. Softee's Avatar
also check all your grounds
Old Oct 6, 2003 | 11:39 AM
Mr. Softee's Avatar
http://www.babcox.com/editorial/ic/ic19730.htm
eld article
Old Oct 6, 2003 | 12:01 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">also check all your grounds</TD></TR></TABLE>
grounds are fine - my car had the same problem billy's had when starting (got a little paint on the ground = no connection = no starty = my wire brush it = then reattach = car startsasaurus.
I think im going to check my connectors, as i let RC connect my wire harness
Old Oct 6, 2003 | 05:21 PM
tegasaurus's Avatar
fixed.... thank you sam...
and for the rest of you... i hope you all have problems with your cars and post on HT and have no one there to help you! kthx
Old Oct 7, 2003 | 11:21 AM
Mr. Softee's Avatar
for search purposes let it be known the clips were reversed between this and one for the charcoal canister i believe
bow tie
Jan 15, 2013 11:38 AM
jillygirl13
Honda CR-V & Element
Jun 11, 2012 06:25 PM
berttheraider
Feb 23, 2008 10:27 AM
AamirCWITR
Jun 25, 2003 01:47 PM
