Does anybodies PASSENGER side seat squeak in there ITR?
Old Aug 28, 2001 | 02:17 PM
TypeR#347's Avatar
Default Does anybodies PASSENGER side seat squeak in there ITR?
I was wondering because mine has been doing it for a few months now and is getting very annoying. It squeaks when I take off, brake and when I hit bumps. Last month I took my car in to the dealer and they were not able to duplicate the problem and neither was I. But as soon as I left the dealer 5 minutes later the seat started to squeak again. So I was wondering if any of u guys have run into this problem before. Thanks in advance guys!!!
2000 ITR#347 Phoenix Yellow
Old Aug 28, 2001 | 02:23 PM
yoshi234's Avatar
I shoot brides
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (TypeR#347)
ahhh, the infamous problem that disappears when you're at the dealer. Hate when that happens
maybe the seat is loose?
Old Aug 28, 2001 | 02:29 PM
TypeR#347's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (yoshi234)
That's the first thing I did is check the bolts and it did not cure the problem. Its seems as though the noise is coming from inside the seat. Hopefully it will keep squeaking so the dealer can see it and order me a new seat. Any more suggestions???
Old Aug 28, 2001 | 02:31 PM
Type Goch's Avatar
New User
is the sound kind of a click sound? my drivers side does that...havent fixed it though.
Old Aug 28, 2001 | 02:41 PM
Reid's Avatar
Global Moderator
Sounds like you have no choice but to get a set of racing seats
Old Aug 28, 2001 | 03:10 PM
BLITZ's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (Reid)
I have the same problem. I found out it wasnt the seat, it was the mmmm, I dont know xactly what thing is called, but its that thing where the seat belt connects to (sounds childish I know). Its on the right side of the driver seat. You know, where you press to release the seat belt. I hope I am making sence, sorry. But anyways, I was hearing a squeak when I would hit bumps & I found out it was that. Try moving yours around to see if its the same problem, either the passenger's side or the driver's side. Maybe some WD40 should eliminate that.
[Modified by BLITZ, 4:12 PM 8/28/2001]
Old Aug 28, 2001 | 03:14 PM
Flux's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (BLITZ)
ahhh... I have been chasing a squeak in the back seat for weeks now....
Old Aug 28, 2001 | 03:30 PM
95LSS's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (Flux)
I've found 2 causes for squeaks in my LS.
1. The headrest is a little loose in the seat.
haven't found a cure for this one other than removing the headrest.
2. The spring under the seat comes with a foam pad between the coils from the factory and if it slips out the spring squeaks.
I need to fix this one on mine again.
Old Aug 28, 2001 | 03:32 PM
nsxtcjr's Avatar
New User
I have this. It's kind of a clicking or cracking sound. And as BLITZ notes, it's coming from the passenger side B pillar.
Since my car's under warranty, I figure I'll have them take a look at it next time I'm at the dealer.
Old Aug 28, 2001 | 03:35 PM
MintyDip's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (nsxtcjr)
mice are living inside the cushion of ure seats
tehy get scared when u drive fst and squeek
leave some cheese out side of the car, and problem fixed
hehehehe I have this problem too in my gsr......wtf is it?
Old Aug 28, 2001 | 05:00 PM
GSR18's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (95LSS)
I also have a squeaking on my driver side seat. It's very annoying. Tried WD40 on the springs but after awhile the squeaks return. Any idea for fixes for this problem?
Old Aug 30, 2001 | 06:26 PM
itr980923's Avatar
New User
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (GSR18)
after listening to the squeal for 3 days and seat was adjusted twice by the dealer, i finally found that the squeal was coming out from the seat belt anchor.
Old Aug 30, 2001 | 10:12 PM
Cyberorth's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (itr980923)
Goddam sonovabitch I am so happy you guys have the same problem as me. hehe.
Now fix them and tell me how cuz I'm sick and tired of looking for cracks and squeeks and hisses and clicks and clings and toots and ... and... (gasping for air)
Old Aug 31, 2001 | 12:44 AM
redteg1's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (Cyberorth)
i know exactly wat ur talking about but my squeaking is coming from MY seat so i have to hear that **** up close when driving...its the kinda squeak type noise u would expect to hear from say....a squeaky old bed....u know that "queek queek" sound... oh well..i just turn the radio up and problem solved
Old Aug 31, 2001 | 01:25 PM
albert butterbikini's Avatar
New User
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (redteg1)
Had the same problem in my GSR, it was the drivers seat though. the noise was coming from the seat belt buckle. if you disconnect your lap/shoulder belt from the buckle and just move the buckle around you will hear it squeak. I had to take out the whole seat so that i could remove the buckle anchor bolt and then i put a thin coat of grease on the bolt and washers and that took care of it.
Old Aug 31, 2001 | 02:29 PM
Rondo's Avatar
Default Re: Does anybodies PASSENGER side seat squeak in there ITR? (typeR158)
My squeak is coming from the passenger side door panel, not the seat. If I reach over and press against the bottom of the panel, it stops. Just haven't taken the time to fix it yet, but I'm sure I can figure it out. The SLOWWWWWW window power is driving me crazier than that squeak though.
95civicdriver
Acura TL, RL & ZDX
Apr 8, 2010 05:54 PM
Tanner
Nov 5, 2007 07:06 AM
onyx00
Jun 11, 2002 07:11 AM
electronspeeder
20
Apr 2, 2002 03:24 PM
