RS front Brake Caliper and rotor info needed
Well i have been searching for an hour now and since H-T don't support two letter searches. i was out of luck.
Well here is my question...
Are the calipers in the 95 teg RS any better than the DX calipers?
If so do i just need to buy a bracket and caliper and bolt it on? or do i need the spindle too?
RS front brakes
DX front Brakes
RS front brakes
DX front Brakes
well if found out that the RS rotor is bigger then the DX's and is the same size as SI's.
All i need to find out is if the rotor and caliper will just bolt up or not on the stock DX hub/spindle
RS front calipers are slightly bigger than the civic ex/si calipers. They use the same mounting holes but the RS have a bigger piston i think. You will need either civic ex/si front spindles or some from any integra.
Redline96LX
37
Feb 20, 2012 02:53 PM
Mr_Bojangles
May 18, 2004 03:27 PM
cnydelSolHybrid
Feb 16, 2004 07:30 PM
