5G DX Big Brakes...Whats the deal?
All I can find are ex and si big brake systems. Due I believe to the fact they were the only ones with ABS.
Can I use the si/ex big brake kits on my DX?
- If yes, with and modification, and if so what?
- If no, are their any available for the dx?
thanks, I got this thing going. Now, I need to make sure I can stop it
Re: 5G DX Big Brakes...Whats the deal? (Mr_Bojangles)
most si front brake are identical with only the caliper differing but no rotor size difference. rear brakes on the Si are usually disc which can be used for the swap. EX on the other hand uses 10.3" brakes on most models (some will have standard size 9.5" rotors)
best to look for 94-01 integra front and rear brakes. for the front get complete knuckle with rotor/caliper, rear you need a trailing arm again with rotor/caliper along with ecables and brake lines.
everything is a bolt in. as long as you get all the proper parts, and all the parts.
some rear brake help:
http://tech.hybridgarage.com/tech/brakeswap.html
digitaltoad
02-12-2019 05:43 PM
