h22 wiring
Old Oct 5, 2003 | 10:05 PM
sakums20's Avatar
Default h22 wiring
i need help, im installing an h22a into my 2000 civic si. the motor has 95 stamped on it. so i think its obd1? everything is in and it wont start, i think its the distributor. i used the si wiring harness. can somone give me some help. email me at sakums20@hotmail.com
Old Oct 6, 2003 | 04:29 PM
poison's Avatar
Default Re: h22 wiring (sakums20)
I would hit up the Hybrid forum for a better answer, I am always in there, but since I`m in here why not.
But anyway, you need to either convert either the motor to OBD2, or you need to convert your car to OBD1. Either way will work. I would recommend converting the car to OBD1, but I am not sure of your laws, etc.
Using the Si wiring harness, you will need to convert the distributor to OBD1, you can either use the Si plug or the prelude plug (either way).
As for everything else, KS and VTEC are already wired, as for EGR and IAB, that is mainly up to you.
Old Oct 6, 2003 | 08:24 PM
crxrich_kid's Avatar
what month is stamped in front of 95. if its a later month its probably a 96 engine which is OBD II
Old Oct 7, 2003 | 12:04 AM
aeolus's Avatar
Default Re: h22 wiring (crxrich_kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxrich_kid &raquo;</TD></TR><TR><TD CLASS="quote">what month is stamped in front of 95. if its a later month its probably a 96 engine which is OBD II</TD></TR></TABLE>
Thats true.
Old Oct 7, 2003 | 02:54 PM
sakums20's Avatar
on the block, in the octagons are the number 10, 30, and 1 followed by NO.1 95
danni22
Jan 3, 2013 02:22 PM
MassScene
Jun 24, 2009 04:51 PM
cftb16600
Apr 14, 2009 06:32 AM
CivicSI1018
Aug 8, 2004 09:46 PM
89 JDM CRX
Mar 21, 2004 01:49 PM
