FAQ: MPFI swap information
Old Oct 5, 2003 | 06:14 PM
sp00nvtec's Avatar
Default Can anyone explain how to do a mpfi swap??
Ok io got a 88 civic dx hacth.I got that junk dual port i wana do a mpfi swap.I got
Si harness
crx si head and intak manifold
Resister box
1988 crx si ecu.
I just want to know i just plug and play or will i have to tune stuff?
Thankjs guys i tried searching didnt really find anything helpfull.
Old Oct 5, 2003 | 06:26 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Can anyone explain how to do a mpfi swap?? (sp00nvtec)
u tried searching ? I doubt it i just did a mpfi swap a month ago and i found all info on this site. i just pulled 277 results when i searced for mpfi.
anyways go to
http://tech.hybridgarage.com/t...g.htm will answer all your questions.
Old Oct 5, 2003 | 06:56 PM
90Sicvic's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (ind3ciso)
http://www.google.com
Old Oct 5, 2003 | 08:58 PM
Caleb V's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (90Sicvic)
You are going to have to mate parts of the Si harness to your stock DX harness. If you need one built then let me know.
Old Oct 5, 2003 | 09:16 PM
JDMCivicEF9's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (Caleb V)
Hey I need one built. IM me.
Old Oct 6, 2003 | 07:12 AM
redzcstandardhatch's Avatar
something different
Default Re: Can anyone explain how to do a mpfi swap?? (JDMCivicEF9)
its a super easy job. you can do the mpfi swap without chaning the head at all it you want to. some people swear you cant do it without swapping cam/cam gear,but you can. you need the intake manifold, distributer, and all the injectors/fuelrail/throttle body for the si. put that stuff on, do the wiring swap(simple) and plug in the mpfi ecu and your done. for the wiring, you'll need to run 4 wires through the firewall(go through where the ac lines normally do, if you dont have ac, you'll have a rubber plug in the spot). those 4 wires need to be tapped into some stuff, i'm not goin into it right now though, you can search for that sort of thing yourself. its really not difficult.
Old Oct 6, 2003 | 09:14 AM
kagegod's Avatar
I'm going to be doing the DPFI->MPFI conversion soon and it's the wiring I'm still sketchy on. I've searched the site, done the links but I'm just iffy on the whole wiring portion. I guess I'll figure it out as I go hahaha
Old Oct 6, 2003 | 01:28 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
See below for updated links:
Modified by 88DXCRX at 3:25 PM 3/31/2005
Old Oct 6, 2003 | 05:01 PM
kagegod's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">*link*
*link2
*link3
*link4
*link5</TD></TR></TABLE>
Been to every one of those links when you posted them up
Old Oct 15, 2003 | 05:49 AM
rZiViC's Avatar
go to page 2 or 3. this kid ask the same questio, the answer in that page.
Old Mar 31, 2005 | 12:25 PM
88DXCRX's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (rZiViC)
updated link list:
*link1*
*link2*
*link3*
*link4*
*link5*
*link6*
Old Apr 12, 2005 | 06:07 PM
Adrian69's Avatar
New to the site Im doing a mpfi sowap on my DX. I have ben reading and it seid that I can get the wires from the cilender position sensor out the stooc distributer but what coller are theyand in what order do they go thanks.
Old Apr 12, 2005 | 07:35 PM
Adrian69's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (Adrian69)
thanks alot ill just go and buy the si distributer
Old Apr 24, 2005 | 09:57 AM
Adrian69's Avatar
Hey I need help! I have been searching for about a month. I got all the parts for mpfi swap. I put everythinng in and I followed the instructions but the car is all retarted. It doesn't want to stay on! And the check the engine light stays on. PLEASE HELP!!!
Old Apr 24, 2005 | 10:13 AM
Dwight Schrute's Avatar
double check all your wiring
Old Apr 24, 2005 | 12:43 PM
Adrian69's Avatar
Ok I checkt everi ting and it steel runing like shet and the check engen light staise on what ells can it be the ecu burnt or what.Help!!!
Old Apr 24, 2005 | 01:04 PM
Erik_Pb_Foot's Avatar
New User
holly **** you attempted the mpfi swap before learning to type......
what computer are you running? have you checked to see WHICH codes it's throwing?
have to tried another resister box? maybe yours is bad. same with injectors.
Old Apr 24, 2005 | 01:14 PM
Adrian69's Avatar
I'm running a pm6 ecu from a 89 civic. I haven't checked the codes. How do you check the codes?Should i get new injectors and resister box?
Old Apr 24, 2005 | 01:22 PM
Rywire's Avatar
If you dont feel 100% confident, have rywire do it for you http://www.rywire.com
Ryan
Old Apr 24, 2005 | 01:52 PM
Adrian69's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (droppedcrxsi)
How much would it cost?
Old Apr 24, 2005 | 04:23 PM
FalkenSiR's Avatar
What codes are you throwing in the first place? It could be something really simple.
Old Apr 25, 2005 | 03:17 PM
Adrian69's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (fast88std)
I checked the codes and it's trowing code 9 and 14. What should I do?
Old Apr 26, 2005 | 03:52 PM
Adrian69's Avatar
I checked the codes and it's trowing code 9 and 14. What should I do? please let me know.
Old Apr 26, 2005 | 09:53 PM
New User
9* Accord 85-98** Civic 86-98 CRX 85-91 Del Sol 93-97 Prelude 85-98
Cylinder Position (CYP) Sensor
Defective cicuit or unplugged/defective sensor
*N/A to any throttle body injection Honda's
**N/A to V-6 engines
14 Accord 88-98 Civic 88-98 CRX 88-91 Del Sol 93-97 Prelude 88-98
Idle Air Control (IAC) Valve
Old Apr 27, 2005 | 05:06 PM
Adrian69's Avatar
Default Re: Can anyone explain how to do a mpfi swap?? (Erik_Pb_Foot)
Know geting codes 10-9-14and16 how can I fix all this ****
