Help, did not pass emissions...
Old Aug 28, 2001 | 11:47 AM
976's Avatar
976
New User
Default Help, did not pass emissions...
That test shows:
Cruise | HC | CO | CO + Co2
Limit |0220| Passed
Emissions |0056| Passed
Idle |0220| Passed
Emissions |0253| Passed
This part did not pass. (HC (ppm))
If someone knows what the hell this means, and how I can fix it that would be great, thanks!
Old Aug 28, 2001 | 04:36 PM
fixhondas's Avatar
Default Re: Help, did not pass emissions... (prsi)
If you failed HC this means you had too much unburned fuel leaving the exhaust (hydrocarbons). This can be from a failed converter, rich mixture, inaccurate O2 sensor, excessive blowby, etc.
Old Aug 28, 2001 | 07:04 PM
976's Avatar
976
New User
Default Re: Help, did not pass emissions... (fixhondas)
fixhondas: Thanks, good info. Very helpful...
I did some research. Decided to change plugs, rotor, cap, and PCV valve. My MSD ingnition doesn't effect the emissions - so that cancels out. I am planning on doing cardon clean up, then take a long drive to clear out all the junk. If this doesn't work I will keep it posted. Until' then, please add some input on what else I can try. Thanks guys.
Old Aug 29, 2001 | 01:09 PM
fixhondas's Avatar
Your msd controls spark and spark plays a big role in emissions. It would be interesting to see the difference with the msd bypassed.
Old Aug 29, 2001 | 07:58 PM
976's Avatar
976
New User
Would an MSD ignition play a good role or bad, my manager says it should make emissions easier to pass. He's a certified mechanic.
Old Aug 30, 2001 | 02:19 AM
fixhondas's Avatar
It could play either role- it depends on how well it works with commands from the ecu/distributor.
Old Aug 30, 2001 | 04:04 PM
976's Avatar
976
New User
I retook the test - passed!
All I changed was PCV valve and distributor cap and rotor.
Old Aug 30, 2001 | 04:24 PM
TheShad0w's Avatar
run some rxp then go redline and top out and then test again, clean as a whistle
brdude
18
Jun 29, 2013 06:50 AM
21ACEKING
Aug 9, 2012 09:49 AM
mashed_potatos
Mar 18, 2010 12:54 PM
IshbOO
Oct 17, 2005 05:56 PM
