Detrimental effects of leaded fuel?
Old Oct 5, 2003 | 10:04 AM
laughinxxx's Avatar
New User
Default Detrimental effects of leaded fuel?
So I'm looking at this: http://www.jacksonautomachine....nId=7
and notice that C12(108 octane) costs roughly the same as unleaded VP 103(99 octane). So if you aren't running a cat does that mean that the only thing that the leaded fuel can mess up is the O2 sensor? Is there anything else that long term use of leaded fuel can damage on the car?
Old Oct 5, 2003 | 10:29 AM
TurboCX's Avatar
Default Re: Detrimental effects of leaded fuel? (laughinxxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx &raquo;</TD></TR><TR><TD CLASS="quote">So I'm looking at this: http://www.jacksonautomachine....nId=7
and notice that C12(108 octane) costs roughly the same as unleaded VP 103(99 octane). So if you aren't running a cat does that mean that the only thing that the leaded fuel can mess up is the O2 sensor? Is there anything else that long term use of leaded fuel can damage on the car? </TD></TR></TABLE>
Yeah, leaded gas will only mess up your cat and O2 sensor. I haven't heard of any case where leaded gas has hurt a motor. Good question though. Bump for a great question. Maybe someone with more experience and years of racing can give us all more info on leaded gas. Personally, I only run it at the track and I only run unleaded on the street. I wish I could run unleaded at the track, but some of us have no choice when we're boosting a lot.
Old Oct 5, 2003 | 10:39 AM
omega11855's Avatar
leaded gas is actually good for the motor from what i have learned supposedly it cleans deposits of the valves and well thats all i know for sure no need to speculate but yeah i would think other then emissions bs leaded is good for your ****
Old Oct 5, 2003 | 10:54 AM
T4eg's Avatar
Default Re: Detrimental effects of leaded fuel? (TurboCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCX &raquo;</TD></TR><TR><TD CLASS="quote"> Yeah, leaded gas will only mess up your cat and O2 sensor. </TD></TR></TABLE>
Old Oct 5, 2003 | 01:58 PM
speedworks's Avatar
Default Re: Detrimental effects of leaded fuel? (BlueHatch00)
the lead in the fuel lubricates the valve stems, but is not good on the o2.
Old Oct 5, 2003 | 02:01 PM
nsxmatt's Avatar
Default Re: Detrimental effects of leaded fuel? (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">the lead in the fuel lubricates the valve stems, but is not good on the o2.</TD></TR></TABLE>
I always thought the leaded fuel breaks down valve seals over time or at least on the ones in newer cars?
Old Oct 5, 2003 | 02:07 PM
racerboyb18c1's Avatar
Default Re: Detrimental effects of leaded fuel? (nsxmatt)
actually the new gas we get at the pump breaks down the seals in the motor because it contains ethynol witch is a alcohol , and if you know any thing bout alcohol in motors it dries out the seals so u need to change the oil sooner , leaded gas is good **** but causes alot of emmisions so they banned it from street use and went to the new **** that i call swamp water for gas and put alcohol in it to make it run at all ...
Old Oct 5, 2003 | 06:59 PM
Drew Peacock's Avatar
Default Re: Detrimental effects of leaded fuel? (racerboyb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerboyb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">actually the new gas we get at the pump breaks down the seals in the motor because it contains ethynol witch is a alcohol , and if you know any thing bout alcohol in motors it dries out the seals so u need to change the oil sooner , leaded gas is good **** but causes alot of emmisions so they banned it from street use and went to the new **** that i call swamp water for gas and put alcohol in it to make it run at all ...</TD></TR></TABLE>Good news I run 50/50 93 and 114 octane the 114 oct has .58 grams of lead per litre... I got 2 o2 sensors for $30 so not to worried about them. Will you get a CEL once your o2 sensor is gone??
Old Oct 5, 2003 | 07:39 PM
99blackcivicSi's Avatar
Default Re: Detrimental effects of leaded fuel? (turbozxi)
yes i think so i know mine did.
Old Oct 5, 2003 | 10:16 PM
laughinxxx's Avatar
New User
Default Re: Detrimental effects of leaded fuel? (99blackcivicSi)
Ok, one other question. I go through about half a tank of gas(8 gallons) a week. How quickly with the key ingredients in the fuel evaporate out of the tank enough to cause the octane to lower significantly?
Old Oct 6, 2003 | 10:27 PM
laughinxxx's Avatar
New User
ttt, any insight as to the rate of evaporation from the stock tank?
Old Oct 6, 2003 | 11:44 PM
I wouldn't worry about it evaporating in a week espeacially with the gas cap left on i doubt you would lose more then 1 octane point.
Old Oct 6, 2003 | 11:45 PM
out of curisotiy what kind of setup are you running? you might be able to get away with mixing gas and it will be cheaper for you.
Old Oct 6, 2003 | 11:47 PM
Evil84Stang's Avatar
Most of the guy's I race with are runnin' 112 octaine, but we're sittin' at a little higher compression too. That darn domestic stuff! LOL
Old Oct 7, 2003 | 06:10 AM
laughinxxx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">out of curisotiy what kind of setup are you running? you might be able to get away with mixing gas and it will be cheaper for you.</TD></TR></TABLE>
It's a work in progress. I'm trying to figure out how much fuel will end up costing me before I go out and buy pistons. Basically, it will be relatively mild NA build with enough nitrous to get into the 12s. Right now I'm looking at 11.5:1 cr.
Old Oct 7, 2003 | 09:16 PM
you would be just fine mixing gas with the compression you will be fine 2 or 3 gallons of cam2 with the rest of your tank you will be fine.
Old Oct 12, 2003 | 10:40 PM
infinatenexus's Avatar
Default Re: (Evil84Stang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil84Stang &raquo;</TD></TR><TR><TD CLASS="quote">Most of the guy's I race with are runnin' 112 octaine, but we're sittin' at a little higher compression too. That darn domestic stuff! LOL</TD></TR></TABLE>
I am at 12.6-1 on a D-16 Y-8
conceptEG
Oct 15, 2006 10:42 PM
ngq
Apr 3, 2004 10:29 AM
DC2NING
Jan 27, 2004 04:38 PM
StreetRacnGsR
May 14, 2003 05:35 PM
97kmsbb6
May 7, 2003 08:38 PM
