Question: If AC is removed, do you retain heat?
Old Oct 5, 2003 | 08:01 AM
WangChung's Avatar
Default Question: If AC is removed, do you retain heat?
i ask because i am thinking of keeping the AC off when i swap this winter. i know the heater core runs off the radiator, but does the lack of ac effect anything having to do with heat? thanx.
Old Oct 5, 2003 | 08:05 AM
jeremyEG's Avatar
Default Re: Question: If AC is removed, do you retain heat? (97civhatch)
no, you'll still have heat. there is a heater hose that runs to the heater core. the a/c and heat have nothing to do with each other.
Old Oct 5, 2003 | 08:06 AM
samdawgsol's Avatar
New User
AC is a totally different system i thought, besides having an evaporator block some air to engine, its just dead wieght a little more tension on the engine due to compressor belt freely rotating i think.
Old Oct 5, 2003 | 08:15 AM
TREVER's Avatar
just leave the evaporator in and you'll be ok
Old Oct 5, 2003 | 08:23 AM
2camsaam's Avatar
Default Re: Question: If AC is removed, do you retain heat? (TREVER)
Heater will work fine, however, your ability to defrost your windows will suffer, so when it rains, it will become difficult to see.
Old Oct 5, 2003 | 08:26 AM
Noe Kozz's Avatar
Default Re: Question: If AC is removed, do you retain heat? (2camsaam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2camsaam &raquo;</TD></TR><TR><TD CLASS="quote">Heater will work fine, however, your ability to defrost your windows will suffer, so when it rains, it will become difficult to see. </TD></TR></TABLE>
You'll keep your heat, and for the fog problem, I found the anti-fog solution from Rain X seems to work well.
Old Oct 5, 2003 | 10:03 AM
WangChung's Avatar
Default Re: Question: If AC is removed, do you retain heat? (Noe Kozz)
sweet, so leave the evaporator and use some rain-x anti-fog stuff and im set? thanx guys, any more tips?
Old Oct 5, 2003 | 11:25 AM
Slow CX's Avatar
Just take it all out and use the anti-fog. Thats what I did. You should not have that much of a problem being in AZ. Only thing you have there is rain and the anti-fog works fine for me in the rain.
I figure if you gut the car might as well go all out. So that is what I did, BUT its not for everyone.
Old Oct 5, 2003 | 11:37 AM
allmtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noe Kozz &raquo;</TD></TR><TR><TD CLASS="quote">
You'll keep your heat, and for the fog problem, I found the anti-fog solution from Rain X seems to work well. </TD></TR></TABLE>
the rain x works pretty good too
pliskin679
Aug 11, 2010 01:25 AM
///EJ6POWER
Engine Management and Tuning
Jul 20, 2010 06:59 AM
EK k kay
Sep 23, 2005 03:46 PM
discrete
15
Jun 18, 2005 12:57 PM
deeweezy
Aug 12, 2003 06:34 PM
