oem fog question
i just bought some OEM foglights from somone here local. i got everything including the oem switch. now on the harness it has the plugs for each fog and a ground for each one as well. then theres a blue wire that is supposed to go to the switch but it doesnt have the plug connected.
How do i connect the lights to the switch? do i have to go and buy the plug separate or is there a way without it? Also, where does the battery get connected?
n e help would be appreciated.
its pretty vague the way you described it but...i think you might need a female connector to connect the "blue" wire to the switch, and the power wire should be connected to the battery or a some wire with a 12 volt source
alacard
22
Jan 8, 2008 06:28 PM
EJ8chu
Lighting
Nov 30, 2007 12:51 PM
spencedogg
10
May 1, 2003 04:03 PM
