Ground control Question?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">learn how to read the coilovers.
http://www.norcalcrx.org/tyson/coilover.html#05
they can go either way. GC would prefer the stiffer ones up front, but basically given only the two choices, put the stiffer ones in the front for a better ride, rear for performance.</TD></TR></TABLE>
good stuff
Modified by escocrx at 10:17 PM 10/6/2003
good stuff
well my friends just finished and when I looked they 100 is in the front and 180 in the rear. I could almost swear that when I called GC that is the way they said do it. If they are wrong I will change them out tommorrow or Monday
thanks
Matt
thanks
Matt
It rides very smooth I was actually suprised. I lowered it to low so I am going to raise it back up a little in the morning. Thanks for all the help guys.
Oh this is my user name the other is my friends sorry for the confusion
Later
Matt
Later
Matt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by escocrx »</TD></TR><TR><TD CLASS="quote">
jus think about it.
the higher the spring rate the quicker the shock reacts to conditions.
Spring rates do only one thing: they tell you how far the spring will compress under a given load. They have nothing to do with "reaction time" (whatever that is) and the shock/damper is a different piece altogether. A 500 lb/in spring will compress 1" under a 500 lb load. Higher rates compress less under the same load, and lower rates compress more under the same load. Dampers control the inherent oscillation of the spring. Being bouncy and being bumpy are two different things. A bouncy car is under poor control by the dampers. A bumpy car is just stiffly sprung.
Anyway, check out Tyson's link to do the spring conversion to lbs. if that helps you. Otherwise, I think you'll find a more comfortable ride on the street with the stiffer springs up front. Try it both ways and see what you like best...that's the best advice. You can't do it wrong.
jus think about it.
Full Race A6
Jul 30, 2004 07:58 AM
norice
14
Aug 31, 2002 11:56 AM
