142,500 mile tune up?
Old Oct 4, 2003 | 02:49 PM
Thasty's Avatar
Default 142,500 mile tune up?
Thats right baby my 98 GSR has 141k miles on her. Anyway the place i bought it from sent me a letter tellin me I need a 142,500 mile tune up. Whats in that tune up?
120k I did the plugs, wires, cap and rotor... does anything else need to be done, gotta keep this car through college.
thanks
Old Oct 4, 2003 | 02:50 PM
iH8RICERZ's Avatar
Default Re: 142,500 mile tune up? (OnlyNod)
fuel filter?
Old Oct 4, 2003 | 02:51 PM
B2FiNiTY's Avatar
Oil change & Filter
Fuel filter
Tranmission Fluid
Check the timing
Valve adjustment (optional)
Coolant
Old Oct 4, 2003 | 02:52 PM
Thasty's Avatar
Default Re: 142,500 mile tune up? (B2FiNiTY)
dayum, yall reply quick. Yea i did the fuel filter too, the only thing I didnt do was the coolant, forgot about that.
Anyway, I gotta do all this again only 20k later?
Old Oct 4, 2003 | 05:47 PM
MikeTV
Guest
Posts: n/a
do the plugs again.....fuel filter, coolant......fluids, check timing, you should be cool...just make sure you are changing oil religiously
Old Oct 4, 2003 | 08:10 PM
Caffeine Slug's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnlyNod &raquo;</TD></TR><TR><TD CLASS="quote">
No, the 142,500 service is pretty much nothing. Change your oil and filter, check all other fluids, check belts and hoses, check brake pads and rotors.
If you have a Helms manual, the maintenance section will tell you everything you need to do. It's the same as the 22,500 service.
Old Oct 4, 2003 | 08:12 PM
Default Re: 142,500 mile tune up? (Eclipse spanker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclipse spanker &raquo;</TD></TR><TR><TD CLASS="quote">do the plugs again</TD></TR></TABLE>
only change the plugs if you used copper instead of platinum at the 120k service. platinum plugs get replaced every 60k.
brutekiller787
27
Feb 18, 2009 04:10 PM
jhony_ej6
Jul 11, 2008 09:55 AM
vietkangta
Jul 28, 2007 12:43 AM
goowakjai
Jul 15, 2005 10:29 PM
migs
Dec 9, 2002 03:38 PM
