im lost.....what turbo is right for me?
Old Oct 4, 2003 | 12:46 PM
bigwig's Avatar
Default im ******* lost.....what turbo is right for me?
ive been reading and posting on this site for a few weeks now and im ******* lost. i cant find a turbo in my price range that will do what i want.
Here is what im looking for:
250-275whp in my 1994 Acura Integra LS
Im hoping that will put me in the mid 13's on street tires.
I want to have boost through my powerband
I dont want to be killed with tire spin...but obviously some is going to occur
looking to spend about $350
SOMEONE HELP ME...IM LOST!!!!!!!!
Old Oct 4, 2003 | 12:58 PM
InTeGrA B18b1's Avatar
Default Re: im ******* lost.....what turbo is right for me? (bigwig)
if you want a big turbo to make 250+ power it has to have turbo lag and you will not have power through out the whole power band. if you want powerband all through out the power band the turbo has to be small and you wont make that much power at high boost. Boost is expensive , get what you payed for
Old Oct 4, 2003 | 01:04 PM
bigwig's Avatar
i know there is turbo lag...i dont want my boost to die at like 5500 rpm like it would w/ a small turbo...i want it to pull hard to the redline...i want some lag....if i get boost at 2000rpm i will get all tire spin....i want my boost more in the 2750-3000 rpm range...a lil less spin....
Old Oct 4, 2003 | 01:09 PM
Agtronic's Avatar
EDIT : Oops, I didn't notice you didn't want to pay more than $350. That's going to be tough.
A T3 Super 60 would do it.
A T3/T04B S-3 with a Stage 1 wheel in a .63 housing will do it too.
Run 12-14 psi and you should have your numbers.
Old Oct 4, 2003 | 01:26 PM
bigwig's Avatar
thats what i was thinking...but i cant find a super 60 or a T3/T04B from a reputable seller..
Super 60= 60 trim w/ .48 ar right?
but what trim for the T3/T04B
Old Oct 4, 2003 | 01:34 PM
DC2R714's Avatar
Default Re: (bigwig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was thinking...but i cant find a super 60 or a T3/T04B from a reputable seller..
but what trim for the T3/T04B</TD></TR></TABLE>
the .48a/r will die off where you dont want it to. Super 60 in my opinion will spool too slow on an LS motor. I would go with a .57trim .63a/r. This would hold torque all the way to the LS redline and be very efficient at lower boost levels.
Old Oct 4, 2003 | 02:22 PM
Double121's Avatar
IM arturbo on here. He gets precision turbos and can set you up with the right one for your car. Many people have bought from him. Cool guy in person, he knows his shiot.
Old Oct 4, 2003 | 02:24 PM
DaveF's Avatar
Default Re: (Double121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Double121 &raquo;</TD></TR><TR><TD CLASS="quote">IM arturbo on here. He gets precision turbos and can set you up with the right one for your car. Many people have bought from him. Cool guy in person, he knows his shiot.</TD></TR></TABLE>
did u notice the price range..i doubt your can find a new precision turbo for that price..
go check out ebay if your looking for a deal.
Old Oct 4, 2003 | 03:57 PM
DIRep972's Avatar
Smarter than you
Default Re: (2.2Lcivic)
I had a Garret T3 .63AR stage 3 exhaust wheel w/ T04e compressor housing and 57 trim compressor wheel on my LS. @ 6psi it made 200whp, 8psi it made 230whp, and 12psi it made 270whp. Spool began @ about 2500 and it made 8psi @ 3800 and 12psi @ 4400. I couldn't have been happier w/ this turbo on my LS motor. It pulled hardest from 5-6.5k and continued to pull nice all the way to 7.5k. I would reccomend this turbo to any LS owner looking for 250-325whp.
Old Oct 4, 2003 | 05:44 PM
bigwig's Avatar
Default Re: (DIRep972)
can anyone tell me what turbo this is?
http://community.webshots.com/...pos=1
Its a .48 on the turbine side...im thinking it might be a 60 trim which would be great for me...
Old Oct 4, 2003 | 06:30 PM
mamaboy's Avatar
cheapturbos.com ..... or the precision sc34 from Arturbo aka "Art" if that's all you want. i know Art recently got a completely stock GSR from engine to exhaust to the 270whp mark with the sc34
Old Oct 4, 2003 | 06:45 PM
bigwig's Avatar
if i could afford a sc34...i would buy a s34...but since i can only afford about $350...i have to work within that amount...
Old Oct 4, 2003 | 06:51 PM
twkdCD595's Avatar
check out thepartstrader.com and related sites for a t3
http://www.thepartstrader.com/...&DCID=
like something like this seems to be in your price range.
Old Oct 4, 2003 | 06:54 PM
bigwig's Avatar
thanks...too bad a T25 will die off at the top end...maybe ill look around this site and find something...
Old Oct 4, 2003 | 06:57 PM
Raunch's Avatar
Default Re: (twkdCD595)
This is the turbo that I'm currently using. Its a Garrett T3/T4 and i love it.
Old Oct 4, 2003 | 08:25 PM
GSRswapandslow
Guest
Posts: n/a
get any kinda t3/t4e you can find. most of them will do the job and carry you to, and past, redline
but, if you want to be a big baller...and am cheap, like me , go with a Holset Hx35. You can find them for $300 and under. The wheel is comparable to the new GT wheels found in the Precision. The entire map from a 60-1 fits in the HUGE 70% island from this turbo. It's a secret to most...but is by FAR the BEST turbo for the money...ANYWHERE.
Old Oct 4, 2003 | 10:23 PM
Agtronic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">Super 60= 60 trim w/ .48 ar right?</TD></TR></TABLE>
The Super-60 has a 1.900" inducer (and a 2.360" exducer like every other T3). Divide 1.9 by 2.36 and you'll get .8050847. Square that number and you get the trim which is .648 or a 65 trim.
The regular 60 trim has a 1.830" inducer.
The .48 A/R ratio that you speak of is the exhaust housing A/R. It has nothing to do with the compressor. (The only thing that changes between the different trim sizes is the compressorl). Larger exhaust wheels on T3s are refered to as stages. Stage 1 wheel is the standard exhaust wheel. Stage 1 exhaust wheel is good to around 280 bhp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">but what trim for the T3/T04B</TD></TR></TABLE>
I would use the S-3 trim. It's the smallest T04B compressor. It'll flow 37lbs/min. That is good for ~370 bhp, but you'll probably never use that much air.
If ever you want to boost more than ~15 psi, you would be better off using an E trim. The T3/T04E 40 trim would be good. You could get it with a stage 2 exhaust wheel and a .48 housing, so if ever you want to make more than 280 hp, just crank up the boost and the exhaust wheel will be happy to go there.
If you want to stick to the 250-270 range, get the T3 Super-60. You could probably even use a T3 60 trim since it's less expensive than the Super-60.
killa on the Vortex has some of the best prices for turbos on the entire internet. Check him out for sure! [ thread ]
Hope that helps!
k20coupe
Aug 29, 2008 09:59 PM
LadyDc4
Jun 6, 2008 06:21 PM
b16a4
Feb 21, 2007 02:25 PM
egctreg
12
Dec 9, 2005 05:21 AM
Smoke_Screen_Civic
13
Jan 22, 2004 05:13 AM
