Upgraded Header/Intake Manifold studs... info please.....
My head is being worked on at the moment, and while its out of the car i'd like to upgrade the header and intake manifold studs to a stronger metal grade. the stock ones break so often, its annoying. and its so often the bolts fall off because of vibration, and just because they dont like the turbo..
i remember there was a member on this board that upgrade them, but i forgot his sn...
so if u guys have the size of the studs, and a source of where to get some, id appreciate it. i know atpturbo sells some studs, but im not sure they fit this application. thanks guys...
krazy
so if u guys have the size of the studs, and a source of where to get some, id appreciate it. i know atpturbo sells some studs, but im not sure they fit this application. thanks guys...krazy
Jesus, I've never heard of people having a problem with them breaking or coming out! You could just use some lock-tite to keep them in...not sure about breaking though, since I'm sure they're grade 8 and 10 is hard to find...
ive broke a few header studs, and i know of a lot of members that have as well. especially the one right next to the clutch hardline..
the newer b series use bolts i believe, but most people say those suck, because lining it up sucks, so id rather do the upgrade. these things snap like straws dude...
krazy
the newer b series use bolts i believe, but most people say those suck, because lining it up sucks, so id rather do the upgrade. these things snap like straws dude...krazy
Milano97
Jun 17, 2002 12:45 PM
