Firewall
Old Oct 4, 2003 | 10:32 AM
5spdIntegra's Avatar
Default Firewall
So I'm installing my zex kit right now and I can't find a hole in the firewall to run wires from the engine to the cabin. I have a 95 LS
Do I need to drill a new hole or is there a good one I'm not seeing?
Old Oct 4, 2003 | 12:24 PM
B16OnTop's Avatar
Default Re: Firewall (5spdIntegra)
there are some holes there you are not seeing, look for the black caps on the firewall and pop one off and run it through there
Old Oct 4, 2003 | 12:34 PM
NightRiderS2K's Avatar
In-N-Out Burger
Heres one...but is intended for amp installations...
Courtesy of team-integra.net
EDIT** thats the same firewall plug that most people use to plug up the integra rear wiper hole once removed.
NRG
Old Oct 4, 2003 | 02:48 PM
PHiZ's Avatar
Default Re: Firewall (NightRider-gsR)
I use the the tube where the A/C drains through the firewall. Look under the car, you'll see a rubber hose that just dumps on the ground, I'm pretty sure it's for the A/C condensation to dump. You can run wires side-by-side with it.
-PHiZ
Linked
Feb 15, 2010 07:27 PM
Lewd Nate
Dec 4, 2007 05:35 AM
Liquidgsr
Jul 19, 2005 05:04 AM
russellfx
Jan 24, 2005 07:09 PM
one slow coupe
Dec 26, 2004 12:24 PM
