trunk leakes water....help!
Old Oct 4, 2003 | 10:08 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default trunk leakes water....help!
Whenever i open my trunk on the accord after it rains there is a steady stream of water that flows out from around the tail lights right into the trunk. this is pissing me off and i cant figure out why its leaking. Anyone else experience this problem?
Old Oct 4, 2003 | 10:33 AM
all420's Avatar
Default Re: trunk leakes water....help! (92prelude)
Try checking the rubber grommits near your tail lights for wear.
Old Oct 5, 2003 | 09:20 PM
RUBZERK's Avatar
Default Re: trunk leakes water....help! (all420)
Replace tail light gaskets
Old Oct 6, 2003 | 08:11 AM
briq4's Avatar
Default Re: trunk leakes water....help! (RUBZERK)
I had also found that on my 93 that the one way vent on the drivers side was leaking water in as well. It's below the power antenna relay and to the left of it when you are looking at the inside of the trunk. So I siliconed that back and and no water since also did the silicone trick around the tail light old gaskets why spend the extra money on new ones from Honda? Completely dry now.
BigDaddyRich
Sep 2, 2011 11:39 AM
rein1116
Jun 6, 2007 07:35 PM
Ls InTeGrA RaCeR
Jun 4, 2005 03:27 AM
TXGirl
Jul 7, 2003 02:48 PM
crewjones
Dec 22, 2002 02:35 PM
