ABS light
I just put in new axles, and my abs light is on. I can see the sensors are lined up, but when teh axle turns, the abs wheel sensor ring on the axle doesn't go in a perfect circle. Is that normal?
that is not normal and is probably causing your abs light to come on. The ring on the cv joint is a press fit- you may be able to tap it back in to place- if not, you will need a cv joint.
