Nitrous question
Old Oct 3, 2003 | 11:50 PM
Si Erik's Avatar
Default Nitrous question
Ok, I have been reading up on nitrous systems and it seems a lot of the systems activate when you hit full throttle instead of pushing a button. IE: zex, venom and what not. Now my question is, is when you launch when you're racing aren't you hitting full throttle? So would that mean the nitrous is getting injected in first gear as soon as you start the race? I'm really confused on this...can someone explain to me how this works ...
Old Oct 4, 2003 | 12:07 AM
EVIL Hx Coupe's Avatar
Default Re: Nitrous question (CivicSi2000)
I believe you still have a switch to turn it on an off... After you flip the switchis when the throttle thing works...
Old Oct 4, 2003 | 12:09 AM
=GAME='s Avatar
im not sure but i think you have to flip that pilot switch in order for it to activate. my friend has it and he usually flick the switch right before he goes into 2nd.
Old Oct 4, 2003 | 12:10 AM
Si Erik's Avatar
Ya I forgot to mention that..but what's the point of that...cause all the advertisments say stuff like "don't waste time fooling with switches and stuff..." and then you have to flip a switch..I know you have to turn it in but is there any way to tell it to activate in a certain gear?
Old Oct 4, 2003 | 12:22 AM
Default Re: (CivicSi2000)
Why cant you spray first???
My friend does it on his 99 Si. He's had the Nitrous for about 2 years, a 50 shot with I/H/E clutch and runs 13.9's....
Old Oct 4, 2003 | 03:56 AM
underrated's Avatar
You can activate it at any rpm if you use something like an rpm activated switch or some stand alones come with nitrous controls.
Old Oct 4, 2003 | 04:05 AM
B.'s Avatar
B.
400 HP Club
Default Re: (underrated)
usually the kit is wired into the TPS and will activate when your foot is to the floor. You have to arm it by turning it on and it will only spray at full throttle. When leaving the line at the track you don't need to spray in first gear (on street tires) because you will just spin at the line and get a **** 60ft. If you’re clutched and have slicks use it off the line dump it and go. Just make sure that it's not armed when doing your burnout.
Old Oct 4, 2003 | 05:16 PM
Optiks.'s Avatar
Default Re: (THE B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE B &raquo;</TD></TR><TR><TD CLASS="quote">usually the kit is wired into the TPS and will activate when your foot is to the floor. You have to arm it by turning it on and it will only spray at full throttle. When leaving the line at the track you don't need to spray in first gear (on street tires) because you will just spin at the line and get a **** 60ft. If youÂ’re clutched and have slicks use it off the line dump it and go. Just make sure that it's not armed when doing your burnout.</TD></TR></TABLE> Wes told me your to scared to use its just for the bling factor
Old Oct 4, 2003 | 05:33 PM
CrazyHondaBoy's Avatar
Default Re: (THE B)
It be funny if the nos switch was on and doing burnout. LOL
Old Oct 4, 2003 | 05:37 PM
ERA's Avatar
ERA
Default Re: (Optiks)
I sprayed in first... When I launch, I'm not just mashing the throttle, you feather into the power, then full throttle it in first, eat up second.. and go from there...
I miss dat stuff.... 14.2@ 96.6 on a stage 1 clutch, street tires and a stock z6, I/H/E.. in a sol...
Old Oct 4, 2003 | 05:48 PM
MPower332TI's Avatar
Default Re: (delslo26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo26 &raquo;</TD></TR><TR><TD CLASS="quote">I sprayed in first... When I launch, I'm not just mashing the throttle, you feather into the power, then full throttle it in first, eat up second.. and go from there...
I miss dat stuff.... 14.2@ 96.6 on a stage 1 clutch, street tires and a stock z6, I/H/E.. in a sol...</TD></TR></TABLE>
Exactly what this guy said. You should have the pedal on the floor when your launching unless youre on some good slicks. On street tires you would be at full throttle about the top of first. I sprayed my car from first and just speed shifted to second and it worked nice. Ran a 13.5 on street tires. Also yes you have to arm the system by flipping a switch first then i had a switch under my gas pedal for full throttle operation. Nitrous is fun. I miss it.
Old Oct 4, 2003 | 06:19 PM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSi2000 &raquo;</TD></TR><TR><TD CLASS="quote">Ya I forgot to mention that..but what's the point of that...cause all the advertisments say stuff like "don't waste time fooling with switches and stuff..." and then you have to flip a switch..I know you have to turn it in but is there any way to tell it to activate in a certain gear?</TD></TR></TABLE>
no not at a certain gear.. you can have the system wired do its always on but just not push the trottle in all the way..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyHondaBoy &raquo;</TD></TR><TR><TD CLASS="quote">It be funny if the nos switch was on and doing burnout. LOL </TD></TR></TABLE>
yes its helps the burnout a 1000x's i was foolin around w/ the guys at work one night after were closed and one guy asked if you could do and i said i dont know.. well it worked and it was a badass burnout and nice tire mark..
Old Oct 4, 2003 | 07:53 PM
B.'s Avatar
B.
400 HP Club
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks &raquo;</TD></TR><TR><TD CLASS="quote"> Wes told me your to scared to use its just for the bling factor </TD></TR></TABLE>Haha so true.........
GetawayInMoscow
Jan 4, 2007 04:42 PM
95accordh22a
Feb 26, 2005 08:35 AM
JSpin
Aug 18, 2004 06:50 PM
cr-x si
Oct 2, 2002 08:33 AM
