h23 head on f22 block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">Don't you have to heavily modify the coolant jackets since the majority of them do not line up with each other?</TD></TR></TABLE>
yup
someone on superhonda had it done a few years ago, i think it blew up after 5k mile or so
yup
I think it's Prelittlelude has a writeup on how his is going. He put the H22 head on an F22 block.
The H22 and H23 share most of the passages for coolant and oil in the head, aside for the one for VTEC that you remove the oil control orifice for in an H23 VTEC. Reasoning would suggest that the H23 should go on the F22 block about as easily as the H22.
I am seriously considering trying it b/c i have my spare H23 head sittin around, and I'm sure I can pick up an F22 block for cheap.
yup h23 head on a f22 is even easier than the h22,
https://honda-tech.com/zerothread?id=776837
there is the link to my project
for the h23 head you don't need to plug any oil holes, and i think the f22 or even h23 water pipe will work just fine without need for modification.
if you need more info let me know, its pretty easy
