h23 head and h22 block
Old Sep 21, 2001 | 05:28 PM
DLB1994's Avatar
Default h23 head and h22 block
i got a turbo h23 accord and i spun a main bearing
i got my head off the h23 it been ported and big vales so i want to keep that
i cant kind a h23 bottom end and a guy got a h22 one for sale so i was thinking about buying it i know ill lose power but i don't care
will a h23 head bolt right up to the h22 block with not changing anying thing
Old Sep 22, 2001 | 11:07 AM
LudeSi-93's Avatar
New User
Default Re: h23 head and h22 block (DLB1994)
I've heard that they bolt up, but there are oil/coolant passage that might be different, so you'll have to work around that. This is kinda out of the ordinary that you're doing H23A head on H22A block. Most people do the other way around. I've been wanting to do the H22A head on the H23A block. Well, good luck.
Old Sep 23, 2001 | 05:07 PM
speedworks's Avatar
yes it will work as long as you use the h-23 water pump and h-23 timing belt gear
on the crankshaft. blocks have same part #. do not forget to install oil restrictor
from h-23 into h-22 block that is in the oil passage that feeds the head
h23sol
Oct 15, 2008 11:29 AM
pkolaboy
Feb 19, 2008 06:37 PM
DLB1994
Sep 23, 2001 07:26 PM
