Repetitious Clicking Noise When Rolling
Old Oct 3, 2003 | 06:48 AM
DrunkNRacer's Avatar
Default Repetitious Clicking Noise When Rolling
94 accord.. 98k.. While im rolling.. (have to be at least going 10+mph)... I hear a clicking noise coming from the front passenger wheel.. I hear it loud and clear.. Would you guys say its the bearings? Im not that knowledgeable in this area.. anyone care to elaborate?
Old Oct 3, 2003 | 06:50 AM
pogidawgie's Avatar
Default Re: Repetitious Clicking Noise When Rolling (DrunkNRacer)
Try repacking the grease on the main wheel bearing. I had that problem before (18,000 miles) on my Integra and after we repacked the bearings, the noise went away.
Old Oct 3, 2003 | 06:58 AM
spankey167's Avatar
Default Re: Repetitious Clicking Noise When Rolling (pogidawgie)
I could be bearings... Well when i had bad bearings for my 4th gen, it made a rubbing sound... The first thing when i read clicking on your title i thought of the cv joint/axle. It probably got dry and went bad. Check the cv joint out and see if its greased or even torn.
Old Oct 3, 2003 | 10:23 AM
MauiBoy056's Avatar
Default Re: Repetitious Clicking Noise When Rolling (spankey167)
Yeah... Bad bearings makes this annoying rubbing noise... Best bet is that the CV's went bad...
Old Oct 3, 2003 | 09:35 PM
Eddiebx's Avatar
hmmm.....or if this clicking noise gets fast as you roll faster, possibly check you tire treads for a small pebble stuck in it, or a screw or nail in the tire.
Old Oct 3, 2003 | 10:10 PM
98accordVTEC's Avatar
I agree with Eddiebx........i believe that the clicking noise could be caused by a nail or skrew in your tire. I have a 98 accord and i had the same problem. My car had a clicking noise in the front drivers side wheel, and it ended up being that i had a skrew stuck in my tire tread. Good luck fixing your problem.
Old Oct 4, 2003 | 04:24 PM
Default Re: Repetitious Clicking Noise When Rolling (98accordVTEC)
tires are ok.. its definetly mechanical.. how does one go about checking a cv joint.. Is there any cosmetic features i can see while under the car.. any pics of good and bad contrast.
Old Oct 4, 2003 | 06:06 PM
brads94accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">tires are ok.. its definetly mechanical.. how does one go about checking a cv joint.. Is there any cosmetic features i can see while under the car.. any pics of good and bad contrast.</TD></TR></TABLE> basically just turn your wheel to the side so the boot will flex and check for cracks or tears in it, but in your case it sounds like the boot ripped or the clamp came loose and leaked all the grease out so it went bad. check your inner and outer joint, (inner being next to the tranny) (outer being closest to your hub)
Old Oct 10, 2003 | 04:03 AM
93CivicSI's Avatar
Bearings, Outer CV Joints -
pcorad
22
Sep 1, 2014 09:23 AM
JennAMP
Transmission & Drivetrain
Nov 19, 2012 09:02 AM
HondaGuy951
Mar 5, 2011 08:41 AM
Secret Chimp
Feb 9, 2008 01:27 PM
SIK IN DA HED
Feb 22, 2003 03:59 PM
