look how stupid i was, WG fell off on the way to a show!!!!!!!
Old Oct 3, 2003 | 05:38 AM
evoeone's Avatar
Default look how stupid i was, WG fell off on the way to a show!!!!!!!
ill start and say that it fell off becuase i didnt use a thick weld el, just regular dump tubing, the nickel welds holding the steel/cast are perfect, ill probably take it apart today so i can re weld a dumb thick pipe, ill find some schedule 40 at my neighbors machine shop and that bitch aint never falling off, luckily it was 1/2 mile before the englishtown exit, so a muffler shop was able to MIG it temporarily so i could make it from CT to MD and back, this was on friday, but just letting you guys know, use a thick piece in case you didnt
OWN3D!!!!!!!!!!
Old Oct 3, 2003 | 05:44 AM
91tegrals's Avatar
that looks like the ***** how much noise did it make dragging the on the road..
Old Oct 3, 2003 | 05:46 AM
rjardy's Avatar
Default Re: look how stupid i was, WG fell off on the way to a show!!!!!!! (evoeone)
what did you do? modify a manifold to accept an external wastegate?
Rob
evoeone's Avatar
Default Re: (91tegrals)
it didnt drag, we stopped for gas, were cruising, i let go oif gas and it sounded louder, forst thought was the plate of my dump tube fell off (exhauts dump tube not WG dump), then i hit the gas again, stopped and it was hanging by the manifold/vacuum line, so it didnt drag
Old Oct 3, 2003 | 05:47 AM
GreddySi99's Avatar
Default Re: (evoeone)
you can weld to a cast manifold
Old Oct 3, 2003 | 05:48 AM
evoeone's Avatar
Default Re: look how stupid i was, WG fell off on the way to a show!!!!!!! (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">what did you do? modify a manifold to accept an external wastegate?
Rob</TD></TR></TABLE>yep, they are cast and didint come for external at the time, so i drilled it and had my neighbor (machinist/TIG'er) weld it up with nickel, cause you gotta use nickel when welding steel to cast, thethin pipe itself cracked, that was the main fault
Old Oct 3, 2003 | 05:49 AM
evoeone's Avatar
Default Re: (intercooledJRSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">you can weld to a cast manifold </TD></TR></TABLE>ummmm yes you can, ask FFgeoff, you use nickel if not a high content nickel alloy
edit for a javier pic and quote
quote by javier " ya buddy...
another of ffgeons beads, high nickel filler used on a T4 vband housing
told ya so, loks liek cast, and looks like steel to me
Old Oct 3, 2003 | 07:31 AM
Infinity_Racer's Avatar
dang you're lucky in aint fall off...
that had been me and with my luck, the wastegate wouldve dragged on the street, fallen, dumptube cut my oil pan up, and then hit the tire and blow it and then grenade before i come to a complete stop
Old Oct 3, 2003 | 08:52 AM
integranator's Avatar
Default Re: (Infinity_Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">dang you're lucky in aint fall off...
that had been me and with my luck, the wastegate wouldve dragged on the street, fallen, dumptube cut my oil pan up, and then hit the tire and blow it and then grenade before i come to a complete stop </TD></TR></TABLE>
HAHHHAHAHAHA-- I woulda thought the same thing w/ my luck!!!!
le0ftw
Welding / Fabrication
19
Jan 23, 2007 12:23 AM
Pikachu
Nov 1, 2005 08:12 PM
.water
May 20, 2005 11:47 PM
underpressure02
Dec 29, 2003 07:30 AM
turbojdm521
Feb 27, 2003 01:19 PM
