valve clearance woes
Old Aug 27, 2001 | 07:10 PM
91DA9's Avatar
Default valve clearance woes
ok. I just checked and adjusted my valve clearance on sunday. However I think that i used the feeler gauge incorrectly and thought the clearance was wrong and adjusted it when it was right . The only side i adjusted was on my exhaust side and only did it to 4 valves. The car doesn't feel any different in terms of acceleration but i makes a much more pronounced ticking while idling. In addition to checking valve clearance I also changed the sprak plugs to Bosch Platinum, and changed the oil. (checked oil today it is good) any help would be greatly appreciated.
Old Aug 27, 2001 | 10:17 PM
keys's Avatar
Default Re: valve clearance woes (94IntegraGSR-OVR)
if the ticking got louder then you did it wrong..... the ticking should have gotten quieter than before...... some people use the smallest feeler gauge that is in manufacturer specs, then make sure that fits and then make sure the largest gauge in manufacturer specs doesn't fit.......... HTH
Old Aug 28, 2001 | 07:14 AM
91DA9's Avatar
Default Re: valve clearance woes (keys)
it wasn't ticking as loud before. how much does this cost to have it professionally done?
Old Aug 28, 2001 | 08:30 AM
miketegra's Avatar
It will probably cost $40-$50. For about that much, you could get the Helms Acura Shop manual, and a couple of sets of feeler gauges.
It's your choice, of course, but I like to encourage people to do simple jobs like this themselves. Figure if you spend the $ on the manual and tools, you will save that $50 every time you do it. You can impress your friends (and the opposite sex)as you tear down motors and race-prep them, all without setting down your beer OR leaving the barstool.
Old Aug 28, 2001 | 08:42 AM
91DA9's Avatar
Default Re: valve clearance woes (miketegra)
well it was kind of funny because when i did this the first time i was like wow i got this back together without screwing anything up. then *SNAP* ah **** i broke a bolt! I broke one of the posts that holds the valve cover on! apparently my friend is opposed to buying good torque wrenches.
Yeah thats right brian you should have just kept your digitorx!
Old Aug 28, 2001 | 08:46 AM
miketegra's Avatar
I know the feeling. I spent 5 hours last night trying to get a new joystick to work on my computer....grrrrrrrrrrr.
And I wouldnt worry about the bolt that holds the cover - It can probably be easily replaced anyway.
Good luck on whatever you decide to do.
Old Aug 28, 2001 | 12:28 PM
Phat Corolla's Avatar
New User
That happened to me the third time i did my valves. It was lame. Those bolts are crap. It was like 2 bucks at acura though, so you should replace it.
Old Aug 28, 2001 | 11:46 PM
C-speed's Avatar
Default Re: valve clearance woes (Phat GS-R)
You sure you did it right? look here:
http://www.c-speedracing.com/howto/v...lveadjust.html
Old Aug 29, 2001 | 04:39 AM
91DA9's Avatar
Default Re: valve clearance woes (G3-TEG)
i didn't use angled feeler gauges which is probably why i adjusted them incorrectly.
thanks everyone
looks like i have a sunday morning project!
Old Aug 29, 2001 | 05:49 AM
keithv's Avatar
Next time use a 10mm socket on a 1/4" drive. You won't break or overtighten the bolts.
A torque wrench in in-lbs would be good to use also.
HTH.
Old Aug 29, 2001 | 07:33 AM
New User
Default Re: valve clearance woes (breaka_1_9)
That's what I was using!!! Lame, huh? Of course, my car is a 94, so i guess it was bound to happen.
Old Aug 29, 2001 | 07:37 AM
keithv's Avatar
You must have really cranked it on there as I couldn't over tighten the valve cover nuts on my car using the 1.4" drive. My 1/4" drive has only like a 6" handle, though....
Old Aug 30, 2001 | 11:07 PM
New User
I just bought a VALVE ADJUSTMENT TOOL from a Snap-On truck today...I will be trying it out tomorrow morning. I think it will make a large difference in how precise i can get it. I will put up an update tomorrow on how it did.
Old Aug 31, 2001 | 06:30 AM
WOTTEG's Avatar
Buy some ARP bolts too.
Old Aug 31, 2001 | 10:30 AM
New User
Default Re: valve clearance woes (WOTTEG)
Hmm...I just adjusted my Valves again...I used my new tool. Well, I think it did help a bit. It definately made the job easier. I have finally been able to get it ALMOST completely silent. So, to sum it up, if you plan on doing your valves often, i would invest in the tool. Since a lot of us drive pretty hard and try to adjust them every 8-10 thousand miles, I think it would be a good idea for a lot of people. Peace out Y'all.
numotive
Oct 6, 2016 06:57 PM
1990IntegraLS
May 6, 2015 03:07 AM
miksew
Oct 27, 2006 06:50 PM
gamakichi77
Jul 28, 2004 09:56 PM
fe519
Mar 22, 2003 08:53 AM
