new f22a1 valve cover?
Old Oct 3, 2003 | 01:49 AM
Dirk McGirk's Avatar
Default new f22a1 valve cover?
i drew a blank... that top part of the engine (f22a1) that says honda 16 valve is the valve cover right./? im kinda high.. anyways mine looks like **** .. crusty and like it was in the ocean for a few years... anyone know where to buy new ones for resonable price? or can i do somthin like sand and paint mine without fucin it up? whats the proper way to remove it and put it back on without cracking it n ****?
thanks.
Old Oct 3, 2003 | 08:21 AM
StimpyBoy's Avatar
Default Re: new f22a1 valve cover? (Dirk McGirk)
It's just a cover, so you can pretty much do whatever the hell you want to the outside of it. If you sand it, don't screw up the spark plug tube edges or the contact edges of the cover or you may get oil leaks.
To take it off, remove anything attached to it (PCV valve, grounding wires, etc.). Remove the spark plug boots. There are 4 bolts holding it to the head, remove those and pull the cover off.
You may have to replace the valve cover gasket and the spark plug tube seals, if it hasn't been done in a while it's easy and cheap. Also, make sure you torque the valve cover back down properly, otherwise you may get oil leaks around the edges or destroy the new gasket you put in.
While you have the cover off, drape a cloth or newspaper or something over the valvetrain to prevent debris from getting in there. I hope you're not thinking of playing with it still attached, if you do you'd better mask off the rest of the engine bay and the tube seals, etc.
Old Oct 3, 2003 | 09:53 PM
7808's Avatar
Default Re: new f22a1 valve cover? (StimpyBoy)
no id take it off.. can u use regualr high temp spray paint? also my manifold or the cover whatever looks like asscrap too i can hi temp spray paint it or take it off?
Old Oct 5, 2003 | 05:27 PM
mrnicolas's Avatar
I got one that is in excellent shape. I sent you a pm about it. Let me know if you are interested.
Old Oct 5, 2003 | 05:56 PM
iam7head's Avatar
Default Re: (mrnicolas)
if you plan to respray it, you might want to take out the whole thing.
make sure you have a torque wrench to torque the valvecover back.
take out all the gasket and stuff.
stripe the paint, sand, primer and paint
boush95ls
Oct 3, 2009 12:28 PM
lando griffin
Jul 28, 2009 01:06 PM
Ritchie
12
Dec 21, 2006 07:29 PM
bigslimdog
13
Mar 10, 2004 01:33 PM
ActiveAero
Jun 7, 2003 02:31 PM
