JDM Type R rear arms
Old Aug 27, 2001 | 05:17 PM
carblegal's Avatar
Default JDM Type R rear arms
This is the first I have heard of them https://honda-tech.com/zerothread?id=63082
Anybody have any info on these arms? What exactly do they do to affect the suspension? Please post pics of them installed on your car and also how much these things costs?
For those who have done this mod, Did it make a difference? or was it a waste of money?
[Modified by carblegal, 6:18 PM 8/27/2001]
Old Aug 27, 2001 | 05:19 PM
Flux's Avatar
Default Re: JDM Type R rear arms (carblegal)
I saw that post and was wondering the same thing...
Old Aug 27, 2001 | 06:03 PM
Willard's Avatar
http://www.ipsracing.com/
Look under the JDM & USDM Honda parts section. They are there about 1/2 way down.
Tubular vs. stamped steel. The choice is yours.
They are the upper mounting point for the rear suspension.
Will
Old Aug 27, 2001 | 06:06 PM
EPGONZALEZ's Avatar
Default Re: JDM Type R rear arms (Willard)
for about the same price you can get an adjustable one with similar construction...a must for any modified suspension
Bob#455's Avatar
You can check out Mike's short description here:
http://www.ipsracing.com/jdmhonda.html
Old Aug 28, 2001 | 06:18 PM
carblegal's Avatar
Default Re: JDM Type R rear arms (Bob#497)
Anybody have a picture of them installed? How hard was it?
Was the mod worth it?
Old Aug 28, 2001 | 07:38 PM
B18C5's Avatar
JDM JDM JDM JDM. It must be good because it's JDM! I agree with EPGONZALES. Don't bother with that mod. You'll get MUCH more benefit out of camber adjustable arms. Go for the King Motorsports ones if you must have the best. I have no idea how going from a stamped UCA to a tubular one is going to make any difference. It's still steel, it still has rubber bushings and it's the same length.
Old Aug 28, 2001 | 08:24 PM
carblegal's Avatar
Default Re: JDM Type R rear arms (B18C5)
I want to know more info on them because as it was posted that "Spoon says that it was a must" on the BM video.
Old Aug 29, 2001 | 06:07 PM
hondura's Avatar
I ve checked the price for the kingmotorsports ones and they are $375.00.(almost 4 times the price of the JDM arms)
I have the JDM (UPPER & LOWER) arms on my GsR(lower arms for the suspension to fit), but I put them on the same time I put on my Tein HAs. My opinion is that the Upper arms are the bang for the buck, they look a lot better than the stock arms for sure.
I cant really comment on how the perform because I had them put on with the upgraded suspension, but put it this way, Honda designed them to improve the handling of the 98 and up Type Rs in Japan. You cant go wrong with them.
Old Aug 29, 2001 | 06:35 PM
geometro's Avatar
Just had to chime in here on the upper arms...as mentioned before the King ones are $375 or so. Exceptionaly gorgeous and functional pieces that are just about dimensionally identical to the JDM pieces--except for the spherical bushing/bearings on the ends and adjustable length. If you're not going to drop the ride height of your car dramatically (<1") then the JDM pieces are a bargain compared to the King ones. What difference will it make? The rear end "tightens" up (and has a slightly higher affinity for oversteer) because the geometry of the rear suspension stays more consistent because of the tubular steel JDM upper arm does not flex like the stamped USDM version. Although I have not tested the durometer of the rubber bushings, they may be different also: this also leading to a subtle handling difference.
If you're Intera is not slammed so it's scraping bots dots or you're out making a living tracking your car and having adjustable rear camber to the Nth degree is a must, then the JDM upper rear arms are a cost effective method for a minor handling change if you have the extra bucks laying about.
-Geo
Old Aug 29, 2001 | 06:38 PM
N1Spec's Avatar
New User
Default Re: JDM Type R rear arms (EPGONZALEZ)
actually adjustable ones are damn expensive.......
checked this website in the UK, they selling custom adjustable upper arms for 500pounds....... ouchh, however they are Group N spec.....
Old Aug 29, 2001 | 06:56 PM
EPGONZALEZ's Avatar
Default Re: JDM Type R rear arms (N1 Spec)
the inglalls ones are a little cheaper..i think i paid 150 for both..same construction..ill post some pics of them tomolo when i get home from work..
Old Aug 29, 2001 | 07:46 PM
Zeus's Avatar
Hey "speedy"
, the Ingall's suck with the poly bushings... or should I say that they squeeeeeek like a ************... funtionally, I guess they work pretty well. However, I get real ****** tired of greesing them...
geometro,
you forgot to add the fact the the whole reason we(USDM) get the stamped arms is due to the fact the the JDM ones produce less negitive camber... hence, will break loose or rear drift easier(the tightening up that was spoke of earlier)... Honda decided that it would be safer for American drivers to have a little less "tail-happy" a car... Think Dan was selling them for around $100 don't know what IPS was...
Old Aug 29, 2001 | 08:27 PM
hondura's Avatar
i am not 100% sure, but I think it is $150 each side.
Old Aug 29, 2001 | 08:37 PM
t's Avatar
t
Default Re: JDM Type R rear arms (Zeus)
If you want them, they are $50 on ebay.
http://cgi.ebay.com/ebaymotors/aw-cg...item=594747216
[Modified by t, 9:41 PM 8/29/2001]
Old Aug 29, 2001 | 08:44 PM
Mike M's Avatar
Founding Member
Same
Old Aug 29, 2001 | 09:48 PM
Bob#455's Avatar
Default Re: JDM Type R rear arms (TypeRmsm)
Same
$100 for the pair, or just one?
Old Aug 30, 2001 | 07:22 AM
Nick248's Avatar
Godspeed has them ..... I bought them for $100.00 for the pair.
I can't reallt determine the degree of performance gains because at the time, I also install the Tein HA's.
They look hella va lot stronger. I know I always had an issue with the rear driver-side tire not perfectly aligning correctly. Just barely with-in spec.
After I put the rear upper control arms in, it is not an issue anymore.
I'm am happy with the installation. On the track, I was considerably impressed with the handling characterisitics. (with both arms and susp.)
As for installation, its eazy breezy! 6 bolts and you're done!
-Nick
Cobora
Nov 7, 2014 05:37 AM
weatherall123
Suspension & Brakes
10
Oct 26, 2012 11:28 AM
chuckles2
Suspension & Brakes
Oct 29, 2007 12:30 AM
Axel Foley
Suspension & Brakes
11
Jan 11, 2006 02:11 PM
Fink2iCe
Oct 15, 2004 03:51 PM
