Front fork pinch bolt stripped out...should I worry?
Old Oct 2, 2003 | 12:28 PM
Quik89Si's Avatar
Default Front fork pinch bolt stripped out...should I worry?
So I put my Skunk2's on the front of my CRX (rears won't fit over my shocks, whole 'nother story) and the pinch bolt on the passenger side fork (and the threads in the fork itself) stripped out when I removed it. I put it back in, and it does thread in, but at the end it turns and turns. It grabs at one point and at another position it's easier to turn - I left it at the grabbiest point of course.
I'm wondering if this is risky and needs immediate replacing. Can the shock actually slip out of the fork even though the fork is held in at the bottom and the shock is held in at the shock tower?
Thanks for the help -
Alex
Old Oct 2, 2003 | 01:01 PM
R6Boy69's Avatar
Default Re: Front fork pinch bolt stripped out...should I worry? (Quik89Si)
why dont you just replace the forks... they are cheap enough... just have to take a trip to the local junk yard
Old Oct 2, 2003 | 01:05 PM
Redline130's Avatar
I'd replace it. I think there would be a possibility of the strut coming out of the fork during suspension travel. Better to be safe than sorry.
Old Oct 2, 2003 | 08:36 PM
neutron91's Avatar
Default Re: Front fork pinch bolt stripped out...should I worry? (Redline130)
same thing happened to me... the bolt stripped and before i noticed it i had already put thread marks on one of my yellows ... luckily it wasnt too bad... and if they arent tight i doubt they would actually come out of the fork but they can bounce up and down in the fork and make the ride harsher
Old Oct 2, 2003 | 09:05 PM
fourthgenhatchB17's Avatar
Default Re: Front fork pinch bolt stripped out...should I worry? (neutron89)
I have that same problem on my 89 hatch, but i got the car that way. It turns out the previous owner just put a regular slightly undersized bolt through the fork with a nut on the backside. It works fine.
Old Nov 23, 2024 | 05:42 PM
Beezer72 $$$$$'s Avatar
Homotor
Mar 21, 2008 12:47 PM
unhappy_idle
May 16, 2006 09:22 AM
thw_goalie
Suspension & Brakes
Mar 29, 2006 11:08 AM
92Si
Jul 25, 2001 10:37 AM
integra0260
Jul 16, 2001 12:32 PM
