Coompression test results..... help!
Old Oct 2, 2003 | 10:50 AM
daddymaxx's Avatar
Default Coompression test results..... help!
ok I just did a compression test on my car. I cranked it 5 times. And my results were 195PSI all across teh board. so that's good news I guess.
I have a JDM type r motor in my EK. I live in a very high elevation area, so is that why it's kinda low? I thought I should be over 200. Should I have anything to worry about?
thanks in advance.
Also... what should a B18b be at? (we did my roomates' too)
Old Oct 2, 2003 | 10:58 AM
Johnny Tran's Avatar
Default Re: Coompression test results..... help! (daddymaxx)
the main thing is that they are 'linear' or equal across the board. The numbers tell you very little.
Looks good enough to me.....beside the fact I see no mention of boost in your post
Old Oct 2, 2003 | 11:17 AM
bus stop's Avatar
did you press the gas pedal all the way in when you do the test?
Last time I saw somebody do the test w/o the WOT and the result was on the low number.
Old Oct 2, 2003 | 11:22 AM
Default Re: Coompression test results..... help! (branch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by branch &raquo;</TD></TR><TR><TD CLASS="quote">
where's your boost at y0!? </TD></TR></TABLE>
in my garage.....waiting to get bolten on to a 200k mile bucket of trash i call my 'daily driver'
whats your excuse redneck?
Old Oct 2, 2003 | 11:30 AM
vtecvoodoo's Avatar
Future Texas Boy
i spent my turbo fund on pbr </TD></TR></TABLE>
and shocks.
Old Oct 2, 2003 | 01:28 PM
daddymaxx's Avatar
ok I re did the test with the throtle open. I got 205 all teh way accross.
Old Oct 2, 2003 | 03:38 PM
all stock's Avatar
Default Re: (daddymaxx)
a leak would indicate an unequal range of +- 15psi
Old Oct 3, 2003 | 12:02 PM
Chubz's Avatar
a jdm r motor should pull at least 240psi im getting 265 on mine. but there are many factors when doing the test, car at operating temp, valve adjustment, full throttle, carbon buildup.
Old Oct 3, 2003 | 12:22 PM
Andrew 825SM's Avatar
Default Re: Coompression test results..... help! (Jelly Bean)
Crank it 9 times and your numbers will be higher.
Old Oct 3, 2003 | 01:05 PM
all stock's Avatar
Default Re: Coompression test results..... help! (Andrew 825SM)
crank it til it doesn't go up anymore.
Old Oct 4, 2003 | 08:40 AM
daddymaxx's Avatar
yea you're not supposed to crank it more than 5 times.
Boosted Chemist
May 4, 2007 06:33 AM
berettagtz117
Mar 6, 2007 04:09 PM
AzntaggeR
10
Oct 18, 2004 07:25 PM
JunIntegra
Jul 1, 2003 01:40 PM
