Bent valves?
Old Oct 2, 2003 | 01:02 AM
onyx00's Avatar
Default Bent valves?
Reved to 9500 - 10000 by mistake. car idles at 1000 RPM; anything to worry about? I can't afford to fix bent valves.
Old Oct 2, 2003 | 02:25 AM
00MRSi's Avatar
Default Re: Bent valves? (onyx00)
I'm assuming you reved that high on a mis-shift? Hmm. I guess a compression and leak down test can give you some answers. I hope you were able to catch it in enough time and find another gear/neutral..
Old Oct 2, 2003 | 06:34 AM
Larkin W.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">Reved to 9500 - 10000 by mistake. car idles at 1000 RPM; anything to worry about? I can't afford to fix bent valves.</TD></TR></TABLE>
Is the car ticking loud??? Sound different at idle??
I did this recently at MAM Honda-tech track day.. Car idled rough but still at the correct RPM.
Definitely do a compression test though. L
Larkin who gets his car back on Saturday
Old Oct 2, 2003 | 10:10 AM
onyx00's Avatar
Default Re: Bent valves? (EbboyPSi)
No weird sounds, sounds fine at idle.
Old Oct 2, 2003 | 10:30 AM
lanceh's Avatar
25 Year Member
so what was the end result larkin?
Old Oct 2, 2003 | 10:33 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: Bent valves? (00MRSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming you reved that high on a mis-shift? Hmm. I guess a compression and leak down test can give you some answers. I hope you were able to catch it in enough time and find another gear/neutral.. </TD></TR></TABLE>
Definently the leak down and compression test.
AK77
Oct 27, 2007 03:01 PM
SiRGodfather
Jun 1, 2004 11:10 PM
dxhatch93
Jun 18, 2003 09:29 PM
SoSoJeff
Oct 24, 2002 08:53 PM
8400 rpm
Jul 28, 2002 08:57 AM
