Is my subwoofer blown?
Old Oct 1, 2003 | 07:56 PM
aaaallll04's Avatar
Default Is my subwoofer blown?
ok so i put in 2 new jl subs today and after about 3 hours i was driving home and i turned it down (i never really had it turned up all the way either...the subs are about 3 weeks old) and i noticed that one of my subs was making a rattling noise. I opened my trunk and i saw it was the left one so i applied really weak pressure to the center of the left amp and the rattling stopped and it was making normal thumps. Think its blown? or just loose screw? or what? Thanks yall
Old Oct 1, 2003 | 08:25 PM
aaaallll04's Avatar
Default Re: Is my subwoofer blown? (aaaallll04)
or not
Old Oct 1, 2003 | 10:30 PM
ATF Kuk's Avatar
push down on the cone with light pressure and hear the suspension for unwound coil. also compare the suspension with the other sub. if its different, then its probably blown
Old Oct 2, 2003 | 06:57 AM
acuradriva's Avatar
Default Re: Is my subwoofer blown? (ATF Kuk)
you applied pressurre to the amp and the rattling stoped? is it mounted to the box? if so move it to a diff spot or tighten it down
Old Oct 2, 2003 | 01:18 PM
boricuacivic357's Avatar
Default Re: Is my subwoofer blown? (acuradriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradriva &raquo;</TD></TR><TR><TD CLASS="quote">you applied pressurre to the amp and the rattling stoped? is it mounted to the box? if so move it to a diff spot or tighten it down</TD></TR></TABLE>
I was thnking the same thing. One other way to check to see if they are blown is to take a 9v battery, take the leads from your sub box and put them to the corresonding polarity on the 9v battery. If the subs excurt and stay that way until you remove the wires then they are fine. If they don't then it's a good chance that they are blown.
mrdeadman
Audio / Security / Video
18
Mar 4, 2007 02:42 PM
hometheaterman
12
May 23, 2005 09:32 AM
SNsLude
Apr 5, 2005 12:15 PM
Supta
Nov 18, 2004 10:24 PM
97Civic-R
13
Jun 15, 2003 05:10 AM
