Sub wont bump.
Old Mar 1, 2007 | 04:32 PM
mrdeadman's Avatar
They let me pick
Default Sub wont bump.
I just installed a new amp because my other one's outputs weren't working. My amp powers up and everything, just the sub isn't getting anything. Any suggestions on what's wrong?
Old Mar 1, 2007 | 04:42 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Sub wont bump. (mrdeadman)
pop the sub to make sure its is not blown
Old Mar 1, 2007 | 06:02 PM
mrdeadman's Avatar
They let me pick
Default Re: Sub wont bump. (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">pop the sub to make sure its is not blown </TD></TR></TABLE>
Well, when my first amp quit working I pulled the sub and it didn't smell burnt, and didn't look burnt and when I move it in and out it doesn't make grinding noise, but it is kind of hard to push in, I don't know how hard it's supposed to be... but tomorrow I'm hooking my sub up to a friend's amp to see if it is blown. What would cause the outputs of an amp and/or a sub to blow at the same time?
Old Mar 1, 2007 | 06:17 PM
02 accord's Avatar
You overload the amp, the outputs fry, sending a high voltage to the sub. That fries the sub.
Old Mar 1, 2007 | 07:30 PM
01d17's Avatar
Default Re: Sub wont bump. (02 accord)
yeah probably blew the sub.if you have a multimeter put it on the Ohms reading and put it on the sub and see if it reads anything, if it doesnt,push on it and see if it does,dependin on the sub it will probably read close to 4 or 2 ohms if it is good
Old Mar 2, 2007 | 10:19 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">You overload the amp, the outputs fry, sending a high voltage to the sub. That fries the sub.</TD></TR></TABLE>
Overload as in turn up too loud or overload as in the fuse didn't blow when it was supposed to?
Old Mar 2, 2007 | 10:28 AM
02 accord's Avatar
Either turned up too loud or running too low of a load, or both. Either way, the amp would overheat and something would fry.
Old Mar 2, 2007 | 10:45 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Either turned up too loud or running too low of a load, or both. Either way, the amp would overheat and something would fry.</TD></TR></TABLE>
I opened up the amp and nothing looked scorched. I'm thinking it was something internally on the board. This was after I had it checked by a quality auto sound just to make sure it was toast... Thanks for the info by the way.
Old Mar 2, 2007 | 11:03 AM
02 accord's Avatar
I've had outputs short out internally with no visible damage on the outside. It doesn't always have to blow up.
Old Mar 3, 2007 | 10:02 AM
mrdeadman's Avatar
They let me pick
Alright, the sub is giving me resistance, but there is no power to the outputs on the amp, so I think that the headunit's RCA sub outputs are bad, which is unreasonable because it is a brand new head unit. Can I use the front or rear speaker RCA outputs and run the sub off of them? I have a hifonics zxi8006 amp.
Old Mar 3, 2007 | 10:09 AM
fcm's Avatar
fcm
Old Fart
Yes you can, all you need is a poor ground on amp to "blow" the RCA outputs on a HU, amp will try and get it's ground through the RCA signal return, almost always common with chassis, it blows the signal return trace on the circuit board, opening the circuit so no signal. it should have no effect on the front and rear RCA outputs. 94
Old Mar 3, 2007 | 10:18 AM
mrdeadman's Avatar
They let me pick
Default Re: Sub wont bump. (fcm)
Exactly how do I check if the RCAs are getting voltage, do I put the + on the inside piece and the negative on the outside piece of the + RCA cable?
Old Mar 3, 2007 | 11:21 AM
fcm's Avatar
fcm
Old Fart
You can connect a small speaker to the inside and outside "pieces" of the HUs RCA outputs, disconnect any speakers that are powered by the HU, turn up the volume, if you hear something the output is working.
I have an old set of headphones that I cut the headphone jack off of and connected a set of alligator camps to, left and right pos.(+) to one and the neg.(-) to the other, but any speaker will work. 94
PS, yes you can use a meter set to AC volts and connect the way you discribe, voltage will fluctuate but go up as you turn the volume up.
Old Mar 3, 2007 | 11:25 AM
mrdeadman's Avatar
They let me pick
Nice, thanks.
Old Mar 3, 2007 | 01:58 PM
mrdeadman's Avatar
They let me pick
None of my RCA outputs work at all. So should I just wire up the loc?
Old Mar 3, 2007 | 02:32 PM
fcm's Avatar
fcm
Old Fart
Your sure? 94
Old Mar 3, 2007 | 03:24 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Your sure? 94
Yeah. When I plug them into the amp, with brand new RCAs I the speaker outputs on the amp don't get any power. I plugged them in right. I don't know what else could be the problem. I just put the loc in and it works now so I'm happy, until I put new speakers in, then how will I be able to amp them if none of my RCA outputs work?
Old Mar 4, 2007 | 07:02 AM
fcm's Avatar
fcm
Old Fart
Time for a new HU. 94
Old Mar 4, 2007 | 02:42 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Time for a new HU. 94</TD></TR></TABLE>
Can't I just put an LOC on the front and the the rear speaker wires and then amp them? I just bought a new HU. Or, maybe they RCAs don't work when you have speakers run off the deck itself?
lsvtek
Audio / Security / Video
42
Feb 11, 2007 09:55 PM
JohnnyEF
Nov 26, 2006 12:04 PM
Dub C
Feb 7, 2006 07:15 PM
silentblackhat
Dec 28, 2005 11:58 AM
sexyaccord
Sep 23, 2003 01:45 PM
