Problem! Just did compression test now car wont start!!!
Old Oct 1, 2003 | 07:52 PM
ownedbyvtec's Avatar
Default Problem! Just did compression test now car wont start!!!
I just perfomred a compression test and everything went fine. After i was done i tried to turn my car back on and it wouldnt start. I checked all the plugs and wires everythings in the rite place and in working condition. I was thinkin the cylinder got full of fuel and now it wont ingnite? how can i solve this problem!? Need HELP ASAP!
Old Oct 1, 2003 | 07:59 PM
Renegade's Avatar
Default Re: Problem! Just did compression test now car wont start!!! (ownedbyvtec)
did you put the fuse for the fuel pump back in?
sorry to have to ask but sometimes I forget stupid **** like that, I kept forgetting to plug the Dizzy back in when I did a mini me swap.
if it is full of fuel just take out the spark plugs and let it dry, but it shoudl be since you are supposed to unplug the fuse for the fuel....
all i can think off for now
Old Oct 1, 2003 | 08:50 PM
B U N M A N G O's Avatar
does it crank at all?
Old Oct 1, 2003 | 08:55 PM
FourDoorTypeR's Avatar
Probably fuses, I've done that before myself.
Old Oct 1, 2003 | 09:02 PM
splitime's Avatar
I'd guess fuse, been there done that.....
Old Oct 1, 2003 | 09:14 PM
B2FiNiTY's Avatar
Maybe your battery is dead from all the cranking.
Old Oct 1, 2003 | 09:15 PM
DB2-R81's Avatar
25 Year Member
Default Re: Problem! Just did compression test now car wont start!!! (splitime)
If you did not unplug the distributor or disconnect the power to the distributor before you did the compression test you likely burnt the coil or igniter and now have no spark. This is the result of the power having no where to go but through the weakest outlet. You now need to replace the damaged parts.
Old Oct 1, 2003 | 09:19 PM
Boostfed's Avatar
New User
Default Re: Problem! Just did compression test now car wont start!!! (DB1-R81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB1-R81 &raquo;</TD></TR><TR><TD CLASS="quote">If you did not unplug the distributor or disconnect the power to the distributor before you did the compression test you likely burnt the coil or igniter and now have no spark. This is the result of the power having no where to go but through the weakest outlet. You now need to replace the damaged parts.</TD></TR></TABLE>
Yep! This happened to me the last time I did a comprression test. Everything went fine, disconnected fuel fuse and plug wires out and took the coil wire off the distrubtor cap, my car wouldn't atart after that. Was a bad coil, just died on me during the test.
Old Oct 1, 2003 | 10:18 PM
Ya i think this is the problem, i plulled out the wires and put a screw driver there to see if it would spark and nothing happend. So theres no spark at all going to my plugs. So im guessin i burned the coil or igniter. Is there any other ways to check if there is a spark?
Old Oct 1, 2003 | 10:39 PM
1OPTION's Avatar
Sounds about rite.
Old Oct 2, 2003 | 04:48 PM
Ek00fbp's Avatar
On c-speed it doesn't say anything about disconnecting the power to the distributor. All it says is to remove the fuse for the fuel injection. Is the power to the distributor that big plastic piece with all the wires. So to undo the power just pull those that big plastic piece apart right?
Old Oct 2, 2003 | 05:11 PM
mugenracer's Avatar
I done the same and burned out the coil.....wont do that again in a hurry!!!
Old Oct 2, 2003 | 05:40 PM
cialz's Avatar
Default Re: Problem! Just did compression test now car wont start!!! (Ek00fbp)
ya where the spark plug wires come out of
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp &raquo;</TD></TR><TR><TD CLASS="quote">On c-speed it doesn't say anything about disconnecting the power to the distributor. All it says is to remove the fuse for the fuel injection. Is the power to the distributor that big plastic piece with all the wires. So to undo the power just pull those that big plastic piece apart right?</TD></TR></TABLE>
Old Oct 2, 2003 | 10:49 PM
Ek00fbp's Avatar
Default Re: Problem! Just did compression test now car wont start!!! (cialz)
what? I know where the spark plugs go and to take them out when testing, but, do I have to disconnect the grey colored sensor I think it is. Its grey plastic piece right next to the distributor that clips together to form one piece, but you can pull it apart into two pieces. is that what im supposed to pull apart aside from removing the spark plug wires from the spark plug holes?
basically how do i disconnect the distributor?
Old Oct 2, 2003 | 10:55 PM
Evs-One's Avatar
Solbros Owns Me
just remove the ECU fuse, all I do. No spark, no fuel
Old Oct 2, 2003 | 10:56 PM
Evs-One's Avatar
Solbros Owns Me
basically how do i disconnect the distributor?</TD></TR></TABLE>
3 12mm bolts, unplug it, and wiggle it out. You'll drip some oil down tho
Old Oct 3, 2003 | 04:58 AM
00 FBP ItR's Avatar
Default Re: Problem! Just did compression test now car wont start!!! (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
3 12mm bolts, unplug it, and wiggle it out. You'll drip some oil down tho</TD></TR></TABLE>
lol.. thats to remove the distributor, he wants to disconnect it to do a compression test.
Just unplug the harness in the rear of the distributor.
Old Oct 3, 2003 | 04:59 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
What?
No, you don't have to "REMOVE" the distributor, just unplug it.
There are two plugs on it, remove the plugs from the clips then disconnect the plugs.
Old Oct 3, 2003 | 11:55 AM
Thank you, you guys are making it too difficult. Pull the ECU fuse and backup fuse, that's all I do. Never fried anything.
Old Oct 3, 2003 | 12:24 PM
Default Re: Problem! Just did compression test now car wont start!!! (FourDoorTypeR)
Well i just replaced my coil today and now the car runs fine again. While i was at it i also replaced the cap, rotor and wires just for a minor tune up since i was already takeing the distributor apart.
Old Oct 4, 2003 | 09:56 PM
That's good man. Glad to here she's up and running again. Next time just pop out the two ECU fuses.
boostmeup51
Dec 1, 2013 12:14 PM
95teg_ls
Apr 21, 2008 08:42 AM
Bngo731
Jun 5, 2006 02:42 PM
xhimurakenshinx
Apr 2, 2005 06:36 PM
xhimurakenshinx
Mar 29, 2005 08:12 PM
