what would it take for a d16z6 to hit 150-160whp?
Old Oct 1, 2003 | 07:13 PM
90da4dr's Avatar
Loved
Default what would it take for a d16z6 to hit 150-160whp?
i was thinking of doing a b18b swap this summer but figured i could have some fun with the sohc. I just bought a 95 4dr civic ex.
From research I have discovered that:
a6 pistons
Port and polished head
crower stage 2 or 3 cam
springs retainers
i/h/e
adj cam gear
light flyweel
clutch
vafc
y8 intake manifold
will net a decent setup
Anything else im forgeting?
Old Oct 1, 2003 | 07:22 PM
MrTodd's Avatar
Default Re: what would it take for a d16z6 to hit 150-160whp? (89civ)
You'll need higher compression pistons than the A6's...
DX (d15b7) pistons are a flat top design, and should bump you into the mid 11's I think. You'll need more than a 10:1 CR.
Also drop in a B-series 60mm T/B (must portmatch the Y8 manifold for this to flow perfectly)
Old Oct 1, 2003 | 07:27 PM
90da4dr's Avatar
Loved
Default Re: what would it take for a d16z6 to hit 150-160whp? (MrTodd)
thanks Mr Todd
any other suggestions
Old Oct 1, 2003 | 07:29 PM
hybridEj6's Avatar
nawz
hahahahahahaha
Old Oct 1, 2003 | 07:32 PM
JaeOne3345's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">You'll need higher compression pistons than the A6's...
d15 pistons in a 1.6 block would sit out of the hole. not good.
Old Oct 1, 2003 | 09:36 PM
Broken Gearbox's Avatar
Default Re: what would it take for a d16z6 to hit 150-160whp? (JaeOne3345)
why dont you get some D16A1 pistons?
Old Oct 1, 2003 | 09:51 PM
90da4dr's Avatar
Loved
Default Re: what would it take for a d16z6 to hit 150-160whp? (James.)
which ones, i heard there are two different ones for 87 and 88-89
but i also heard that the compression ratio would be in the 13's
which might be a little high to drive on 93 octane
Old Oct 1, 2003 | 10:04 PM
Mr Hammond's Avatar
a/k/a Jomo
Talk to Exospeed.
Old Oct 1, 2003 | 10:38 PM
racerboyb18c1's Avatar
Default Re: what would it take for a d16z6 to hit 150-160whp? (Mr Milano)
use the 88-89 a6 pistons and have fun kickin b16 hbs lol
if ur in a hb
Old Oct 2, 2003 | 04:57 AM
infinatenexus's Avatar
the 89-90 A1 pistons are the one to get, they knock your compression ratio up to almost 13-1. with proper tuning, and engine management you can run it on the street with no problems, and obliterate B series cars
Old Oct 2, 2003 | 01:00 PM
90da4dr's Avatar
Loved
Default Re: what would it take for a d16z6 to hit 150-160whp? (racerboyb18c1)
thats the problem, weight, i have a 4dr
i just want something fun and more reliable than a turbo.
im in college
yellowjdmcrx
Sep 1, 2005 06:32 PM
cascaritas
14
Mar 26, 2004 07:46 PM
Renegade
Mar 2, 2004 12:36 AM
hondaboyB18C1
Dec 23, 2003 09:30 PM
SOHC_DK.
Jan 27, 2003 10:32 AM
