setting cam timing
Old Oct 1, 2003 | 06:44 PM
rasta420's Avatar
Default setting cam timing
how do i move the cam gear to TDC for piston 1? i tried to rotate it by the 12mm bolt in the middle of the cam gear under the timing belt, but it only rotated so far, and i didnt want to overtorque or break the bolt.
Old Oct 1, 2003 | 06:57 PM
USDM 4G VTEC's Avatar
Default Re: setting cam timing (rasta420)
1 take all spark plugs off so u dont get compression
and try movin the crank by hand
Old Oct 1, 2003 | 07:04 PM
rasta420's Avatar
Default Re: setting cam timing (USDM 4G VTEC)
i got the crank on TDC, but the cam gear was off. so i took the timing belt so i can set the cam gear to TDC. how do i do it with the timing belt off?
Old Oct 1, 2003 | 07:53 PM
Renegade's Avatar
use a 14mm socket, and turn counter clockwise until the top is top....
lurice01
12
Feb 22, 2017 07:56 PM
jahenderson1
Oct 2, 2015 06:23 AM
SCHYBRID
Apr 5, 2006 05:33 PM
EK4 hatchback
May 31, 2004 08:45 PM
civickiller
Mar 8, 2004 11:34 AM
