install gauges myself?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed »</TD></TR><TR><TD CLASS="quote">ew, yourself, and I dont think so.</TD></TR></TABLE>
if you ask.
I think you should not do it
pay somebody so you dont blame yourself for the mistakes ex:
speedometer not working
gas gage not working
its a lot of headaches..
if you ask.
yeah get someone to do it...it may cost more then the gauges but if you f stuff up you be kicking yourself and it'll cost more to get that fixed...plus if they f it up then you can flip out on the place and have them replace it for free and fix the problem
ok....i dont know **** about electronics and i hooked up my fuel pressure gauge, boost gauge, and fuel air ratio gauge myself.....just follow the directions and you should be fine....it took me a while but everything worked fine. email me if you need some advice. knewfx@yahoo.com
save yourself money, do it yourself. its a good learning experience, its very easy. just follow the instructions. you gotta start somewhere, just have a person with you that knows what they are doing. I imagine out of your friends you have atleast a few that know about electronics. its not rocket science.
<----says do it yourself.
yeah man DIY.
I'm guessing your stock ****'s functional right now, so all you really need to do is examine it before you start unplugging ****, I'm pretty sure it's only like 3 wires or so. ABSOLUTLY no need to pay $50/hr for a job you can do yourself. I just installed an ignition and had never done anything like it before. Unless you're really inept, you won't have any problem installing it I'm sure
BTW, indiglo gauges are gh3y y0, but to each his own i guess
they are sooo easy to install. I would tell you how to do them but there is a how to on Team-integra.net so check it out. The wireing it easy only two wires. Ground and a switched light. The Dimmer switch works great cus it only gets power when the dash lights come on. message me if you need help.
yea dude, i installed some on my dad's subaru no prob.,mounting the trans is the bitch.. everything else is pretty easy. Use double sided tape to mount the faces on. I took them off cuz they were like 5-8 mph off
. I suggest you not get them! keep stock man
The_Honda_Guy
10
Feb 13, 2010 01:17 PM
TwistedSI
21
Jun 3, 2003 04:39 AM
