Alarm Guru's : Alarm removal
Old Oct 1, 2003 | 02:51 PM
Trooper's Avatar
Default Alarm Guru's : Alarm removal
Hey guys i am in the process of removing the alarm from my drag car. Quick question under the dash there is a relay that the 3 of the dash wires go to 1 wire that is cut that goes in to the relay and back out ( I cold Tell by the thickness of the wire and color coding) and the other wire is tapped and goes to the relay. Can I just connect the wire that goes in and out of the relay and un solder the other wire that is tapped?
Old Oct 1, 2003 | 07:52 PM
TurboBumblBee's Avatar
Default Re: Alarm Guru's : Alarm removal (Trooper)
that sounds like a starter kill relay.. just cut it out and connect the wires agian or your car will not start
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
Drifterxs12
Sep 16, 2008 10:56 PM
dem0nk1d
Sep 18, 2006 01:16 PM
arw321
Sep 5, 2003 12:25 PM
cyvic
Aug 3, 2003 06:51 PM
