Hondata is a life saver again!
Old Oct 1, 2003 | 02:34 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Hondata is a life saver again!
Today while coming to work I took my car to a friends shop to let him drive it. I realized for the last couple of days my car seemed to sputter at idle. Well after i left his shop, i boosted just a little as i was leaving and I throw a cel 16 (Fuel injectors). I figured i hit boost cut and it just threw me in Limp mode. Nope...My issue was a faulty injector clip. The actual soldered wire broke and was coming out the clip. Im just glad hondata threw me in Limp mode. .
Moral is watch what you buy even from friends It wasn't done purposely tho.
My motor could have blown today.
Old Oct 1, 2003 | 03:09 PM
IloveNewt's Avatar
Default Re: Hondata is a life saver again! (HybridcivicLS-T)
Glad to hear someone is havin some luck with thier car.
Old Oct 1, 2003 | 04:24 PM
turbo Si's Avatar
Default Re: Hondata is a life saver again! (MordecaiPSI)
That's a plus when you have a system that can detect problems and throw a code. My DFI Gen 7 does them same.
Old Oct 1, 2003 | 04:53 PM
danl's Avatar
Banned
Default Re: Hondata is a life saver again! (turbo Si)
I boosted for 6 miles trying to make it home on 3 cylinders when #1 cylinder injector clip came off. I had to use boost just to make it home LOL. Anyways, it didn't hurt anything. Also, its not so much hondata that saved you as OEM honda that saved you.
Old Oct 1, 2003 | 06:34 PM
rioninja's Avatar
Having one of the injectors not firing will most likely cause no damage.
Old Oct 1, 2003 | 07:56 PM
InTeGrA B18b1's Avatar
Default Re: Hondata is a life saver again! (rioninja)
if your are boosting it 1-4th gear hard , you will run lean and fry a piston or something
Old Oct 1, 2003 | 07:57 PM
Default Re: Hondata is a life saver again! (InTeGrA B18b1)
DETONATION right guys
Old Oct 1, 2003 | 08:22 PM
turbohappy's Avatar
You won't run lean with NO fuel. Well, i guess you technically will but it won't burn so it doesn't count You will if it's partially firing though.
Old Oct 1, 2003 | 08:27 PM
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">if your are boosting it 1-4th gear hard , you will run lean and fry a piston or something</TD></TR></TABLE>
No
Mr. Softee's Avatar
Default Re: Hondata is a life saver again! (turbohappy)
i threw code 16 right before i blew my motor. 6k rpm @ full boost w/ whatever happened to those injectors = no good. pissed me off.
sam
Old Oct 1, 2003 | 08:32 PM
turbod16y8's Avatar
hahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">
No</TD></TR></TABLE>
Old Oct 1, 2003 | 08:33 PM
racinskittle's Avatar
Default Re: Hondata is a life saver again! (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">i threw code 16 right before i blew my motor. 6k rpm @ full boost w/ whatever happened to those injectors = no good. pissed me off.
sam</TD></TR></TABLE>
Gave you a reason to get that new block tho huh
Old Oct 1, 2003 | 09:31 PM
bossman032's Avatar
Default Re: Hondata is a life saver again! (racinskittle)
its was the ECU aka HONDA not honda data.
Old Oct 2, 2003 | 05:58 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Hondata is a life saver again! (bossman032)
it's all good for me just as long as i was saved.
VegasInvasion
Engine Management and Tuning
Mar 5, 2010 09:58 PM
P12 EG6
Dec 5, 2007 08:28 AM
b00sted_GS-R
Nov 19, 2004 09:17 AM
ActiveAero
Nov 12, 2003 07:35 AM
autoEXturbo
Apr 25, 2003 09:41 AM
