question about iac on itr intake manifold
From: chillin in that city called queen creek, but homes the atl
ok the idle air control valve on my integra type r intake manifold is bad what other intake manifold has the same sensor that bolts up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maximus »</TD></TR><TR><TD CLASS="quote">Wrong not all IAC's are the same. Try to find someone local so you can match it up to your IM. </TD></TR></TABLE>and i agree with this guy the iac's are not al the same
so any body else because when i bought my intake manny it was bare and the iac i put on it was just one i had laying around and i don't remember what i took it off of
alot of the OBD1 IAC'S B-Series are longer than OBD2's you want to get the same kind, you cant use ones from D-series because the IAC is different there a 3 wire instead of 2 wire
one more thing you can use OBD1 but you will only be able to get 1 bolt in the maniflod the holes dont line up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 »</TD></TR><TR><TD CLASS="quote">alot of the OBD1 IAC'S B-Series are longer than OBD2's you want to get the same kind, you cant use ones from D-series because the IAC is different there a 3 wire instead of 2 wire
one more thing you can use OBD1 but you will only be able to get 1 bolt in the maniflod the holes dont line up.</TD></TR></TABLE>
so areu saying that i need to get an obd2 iac even tho my car is obd1 and is the iac that i already have on there is obd2
