shifter woo's
Old Sep 30, 2003 | 12:16 PM
EJ8 Kenobi's Avatar
Default shifter woo's
Gotta problem, when I bought my GSR it had a shifter already installed in it. After about of year of driving it. The shifter itself felt to be really lose. I could still change gears and what not but if in gear, it would still move around like in neutral.
I looked under the car and saw the problem. (Sorry, dont know the names of these peices) The shifter itself at the bottom (where the bolt connects it too the shift linkage) didn't fit in the little half H part on the shift linkage. Apparently the guy before me used a bunch of washers to fill the the empty space so that the shifter seemed stuffed in place.
I went and bought another shifter that is supposed to be for the integra. The cylinder shaped peice at the bottom, agian wasn't big enough to fit in the space. So it still rattles around. Did the morons give me the wrong shifter or do I have missing peices?
Old Sep 30, 2003 | 01:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: shifter woo's (FrankGSR)
The bottom of Civic shifters is smaller than Integra shifters, so most shifters out there are smaller so they can be used in Civics, and have spacers to use them w/ Integra linkages. The spacers that came w/ mine weren't thick enough, so I added several washers to take up the rest of the space. I also stuck in a lockwasher to keep everything pressed together so it wouldn't rattle. It's been over 2 years since I put it in and it still shifts beautifully, no rattles, no excessive freeplay or anything.
Old Oct 1, 2003 | 04:36 AM
EJ8 Kenobi's Avatar
Default Re: shifter woo's (PatrickGSR94)
Alright, where did you pick up the spacers at? And did you use just any washer laying around your garage or something special?
Old Oct 2, 2003 | 11:04 AM
EJ8 Kenobi's Avatar
I found a rubber washer and put it on the shift lickage between the cylinder of the shifter and that helped alot. I just need to find another one and it'll be real nice.
Old Oct 2, 2003 | 01:07 PM
Community Builder
I used stainless steel washers, for 2 reasons: 1) they won't rust like regular zinc washers will, and 2) they tend to be more uniform in thickness than plain zinc washers. I put the washers on that throughbolt that goes thru the linkage and shifter.
Old Oct 2, 2003 | 01:11 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrankGSR &raquo;</TD></TR><TR><TD CLASS="quote"> didn't fit in the little half H part on the shift linkage. </TD></TR></TABLE>
That would be called a U
What kind of short shifter did you buy? My skunk2 came with all spacers needed to fill up the U. The same result could be obtained from simple washers.
Old Oct 2, 2003 | 05:18 PM
Tweakmeister's Avatar
http://www.mcmaster.com will have something but it takes a bit of digging around the site. I'd swing by an auto parts place and look around for some odd thing that will work.
I do have a stock '99 Gs-R shifter if you need one. It's barely used as I swapped it for a Neuspeed Short Shifter.
gameknb
Jun 11, 2005 07:32 AM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
Regular Series
Sep 14, 2002 10:41 AM
SOHC_MShue
Jun 20, 2002 02:44 PM
Ekco
Jun 13, 2002 12:36 PM
