Clutch sticking on cold mornings!
HELP! my clutch is sticking it comes up all the way but is very loose after about 1/3 of the way.. this has started to happen ever since it got cold...
I was reading the archives.. and noticed some stuff about the master and slave cylinder.. I'm not exactly sure what they are.. i see 2 thigns i think it is.. but i can't be sure.. the big one has fluid in it.. the smaller one looks like it has a thing inside that's closing the top.. and I can't tell if there is liquid in there..
my car is an EG /w GSR motor..
Thanks
Thanks
Look at the firewall in front of the driver. There's 2 reservoirs for brake fluid. The bigger one is right on the brake master cylinder. The smaller one has a hose leading down to the clutch master cylinder. The reservoir for the clutch has a little plastic float inside it, I don't know if that's the thing you're talking about?
The clutch slave cylinder is bolted onto the transmission, right behind the RH radiator fan. There's a steel tube leading to it, and it has a bleed valve.
https://honda-tech.com/zero...73215
thanks.. I think i got it covered.. still might need to bleed it tho.. the small resevior was totally empty.. filled that up.. and added more to the bigger one..
Thanks!
Thanks!
If it was empty, then I bet you've got air in the lines. Bleed it. Just filling it isn't gonna help.
Besides, the fluid had to go somewhere... Look for leaks again now that it's full.
