What Type of Primer and Paint for Valve Cover Painting?
Old Sep 29, 2003 | 06:44 PM
crxforum's Avatar
Default What Type of Primer and Paint for Valve Cover Painting?
Just wondering what type of brand ect of promer you used. Also is Hi-Temp paint really necessary? It doesnt get that hot on the Valve cover and you only really need HT paint on exhaust manifolds and such. So what do you suggest? Also what brand of paint should I use?
CRX Forum
Old Sep 30, 2003 | 08:26 AM
crxforum's Avatar
Default Re: What Type of Primer and Paint for Valve Cover Painting? (crxforum)
I searched and I only came up with painted ones that had no instructions someone must know.
CRX Forum
Old Sep 30, 2003 | 08:36 AM
OneThirtyEight's Avatar
You dont have to use super high temp paint... Any automotive quality paint will work. Use any automotive primer on it. Use aircraft coating remover to remove the wrinkle finish, will take it down to the metal, you dont really need to use a primer, just strip it with aircraft coating remover, then sand it down a little and ptu a few coats on paint on it.
Old Sep 30, 2003 | 08:43 AM
BauleyCivic's Avatar
Risky Business
Default Re: What Type of Primer and Paint for Valve Cover Painting? (97blackteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97blackteg &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to use super high temp paint... Any automotive quality paint will work. Use any automotive primer on it. Use aircraft coating remover to remove the wrinkle finish, will take it down to the metal, you dont really need to use a primer, just strip it with aircraft coating remover, then sand it down a little and ptu a few coats on paint on it. </TD></TR></TABLE>
Yes, I'd recommend using high temp paint. I stripped it with aircraft coating remover, then used 5 coats of engine rebuilder's cast grey...can be found at any advance auto parts location. I'm waiting to redo a new one in wrinkle red.
14eight's valve cover:
Old Sep 30, 2003 | 08:50 AM
crxforum's Avatar
Default Re: What Type of Primer and Paint for Valve Cover Painting? (BauleyCivic)
What did you guys use for the letters and H logo? I know about Vaseline and stuff like that but it is really tricky. Also using tape can peel the paint when you remove it. Should sandpaper be enough to clean off the tops of the lettering?
CRX Forum
Old Sep 30, 2003 | 12:13 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">What did you guys use for the letters and H logo? I know about Vaseline and stuff like that but it is really tricky. Also using tape can peel the paint when you remove it. Should sandpaper be enough to clean off the tops of the lettering?
CRX Forum</TD></TR></TABLE>
Yep...I sanded the paint off of the H and Honda when all was said and done
Old Sep 30, 2003 | 12:17 PM
WhatThaFrig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Yep...I sanded the paint off of the H and Honda when all was said and done </TD></TR></TABLE>
Sand it off then polish it with some Wenol then clear it. It'll look real good then.
Old Sep 30, 2003 | 01:41 PM
ATS*Mark's Avatar
OG triple OG
Default Re: What Type of Primer and Paint for Valve Cover Painting? (WhatThaFrig)
i used aircraft stripper to get all the **** off mine , then 5 or 6 coats of duplicolor hi temp flat black , then i sanded my honda letters down , i have yet to wax it i was thinkin mothers billit polish
Old Sep 30, 2003 | 01:46 PM
ATS*Mark's Avatar
OG triple OG
Default Re: What Type of Primer and Paint for Valve Cover Painting? (TURSpoonEK)
**** i forgot a pic , what an ******* i am.......
adamisgreat88
17
Jun 8, 2009 02:52 PM
realxfresh
Mar 28, 2009 11:48 PM
Dxs
Dec 2, 2006 05:49 PM
maluseanjohn516
14
Dec 8, 2005 06:28 PM
JDMTurboCivic11
Mar 6, 2005 08:09 AM
