Car boggs at Full Throttle after obd0-obd1 conversion?
Old Sep 29, 2003 | 06:28 AM
90teg's Avatar
Default Car boggs at Full Throttle after obd0-obd1 conversion?
just did an obd0-obd1 conversion. after lots of kicking and screaming, there are no more check engine lights. BUT after about 2500rpm if hit full throttle the rpm goes nuts. it goes to up and down crazy. it does this at about anything over 50% plus throttle. i have NO idea what the hell is wrong with my car. can anyone shed some light PLEASE.
Old Sep 29, 2003 | 06:38 AM
ltho1998's Avatar
Default Re: Car boggs at Full Throttle after obd0-obd1 conversion? (90teg)
My car did the same thing when i reversed the plugs from my MAP and TPS. So I figure it has to be somewhere on the MAP or TPS.
Check for continuity between the plug on the sensor and the corresponding wire on the ecu plug.
It could also be possible that the harness was put together incorrectly and a wire might be switched
Just giving you pointers to start w/
Old Sep 29, 2003 | 06:47 AM
90teg's Avatar
Default Re: Car boggs at Full Throttle after obd0-obd1 conversion? (ltho1998)
Thanks, i totally forgot about the map sensor.
Brandon Hartman
Nov 21, 2018 02:03 PM
Zack Gunther
May 22, 2013 09:35 AM
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
jphil101
Apr 2, 2010 11:36 AM
JaymieTypeR
Oct 9, 2004 12:49 PM
