Dash swap= HVAC controls don't work. Only get air out of face vents. Help.
The buttons don't work on the climate control. The air heats up when I move the slider, and the fan works. When I try to change where the air comes out, it stays at me face. I get no air on my feet or as a defogger. I checked all electrical connections, but I didn't find anything. The car is a 92 civic cx and I swapped the stock grey dash for a black one. I put the grey dash into another civic, a 95 cx, and now that car has the same problem. Can anyone shed some light on this problem? Thanks.
all the cables are hooked up. I can switch between heat and cold, but I can't change which vents the air comes out of. It worked right before the dash swap.
sounds like you forgot a vacuum hose connection somewhere or cracked/tore one of the vacuum hoses...
all the buttons/sliders do is act like valves for the various vacuum lines which hook to the vacuum pots on the a/c doors in the housing behind the dash. They are all connected at a few points so one hole in one or one disconnected one and they'll all cease to function as there will be no vacuum signal in the system. And no, the engine won't run rough with a hole in the vacuum system for the a/c as there's a check valve at the firewall to prevent this...
I want to know too, my vents switches still dont work after my car was recovered from a theft. I even bought a new heater console deally and it had the same result.
go to pepboys and pick up the book, i forgot what its called but i used to have one for my blazer, but its got all kinds of mechanical information in it, it shouldnt be more then $12
and its worth every cent
Chilton manual? It ain't worth ****. It's very vague. I guess it helps a little, by I didn't find the answer to this problem in it. Maybe there is a better manual.
me and a friends switched dashes and his wont do anyhting but defrost, my postion control works but i cant change the 1-4 settings? like how much air i dunno why i havent messed with it much tho
My car had the same problem, although I didn't change dashes, I got a different climate control and then the Floor air and defroster worked again.
Maybe try that???? I dunno other than that
I figured it out. I missed a plug and now I have pictures!
I started looking here, behind the glove box. The green circled plug controls the fresh air/recirculation. The plug circled in red controls the fan motor.
In this picture, the yellow circled plug goes to the radio, the teal goes to the cigarette lighter, and the red plug is the dangler. This is the plug I forgot to plug in. I tested wires with a volt meter and made sure everthig was plugged into the climate control. It was as simple as a plug that didn't get plugged in. Good luck with yours!
Well maybe someone can help me, my controls work fine, except it wont blow at all. But when i press the brakes hard for a few seconds it will kick on...then back off...Its wierd...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx »</TD></TR><TR><TD CLASS="quote">Well maybe someone can help me, my controls work fine, except it wont blow at all. But when i press the brakes hard for a few seconds it will kick on...then back off...Its wierd...</TD></TR></TABLE>
Bad ground? Anything else in your car shorting out?
umm my right brake light doenst work....like everything is plugged in, new bulb and everything and it jsut doenst work..the other 2 brake lights work...
i did a dash swap too so maybe thats what it is a ground...hmm i really dont wanna take my dash part to search lol
Check all the plugs under the dash to the left of the steering wheel. I remember there were a couple there.
85_305
16
Feb 4, 2009 04:12 PM
