Quick Question: 16valve=dx head?
Old Sep 28, 2003 | 06:57 PM
Slow89HB's Avatar
Default Quick Question: 16valve=dx head?
Hey, my shortblock is stamped d15b1, but the valvecover says 16valve. what does this mean?
i searched but am still not sure
Old Sep 28, 2003 | 08:07 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Quick Question: 16valve=dx head? (Slow89HB)
All 88-91 Civics had the 16v head.
d15b2 = dx
d16a6 = Si
Not too sure about the 1, but I assume a HF motor.
Old Sep 28, 2003 | 09:34 PM
skud_dusty's Avatar
Default Re: Quick Question: 16valve=dx head? (Todd00)
isnt the HF an 8 valve motor?
Old Sep 28, 2003 | 09:37 PM
91civicDXdude's Avatar
the HF, otherwise known as D15B6, is an 8 valve engine with flat top pistons that have 2 valve reliefs per piston (MPFI). the D15B1/D15B2 are 16 valve DPI engines with 16 valve-valve reliefs. an interesting fact however, is that the D15B8 (92-95 CX) has an 8 valve head, but with 16 valve valve reliefs on the pistons, leading to the slightly lower compression its rated at. If someone were to confirm that a VTEC head's valves would clear the HF's pistons with missing valve reliefs, you could slap a VTEC head on a D15B6 block and have even higher compression than with a normal flat-topped D15 mini-me
Old Sep 29, 2003 | 06:23 AM
xci_ed6's Avatar
Default Re: (91civicDXdude)
I think it has been confirmed that 16V heads (at least the B2/A6 ones) will not clear the flat top pistons.
-Dustin
Old Sep 29, 2003 | 07:39 AM
Z6/Y8 heads will clear the D15B1/B2/B8 flat top pistons....and i've "heard" of HF mini-me's.. but that is not yet confirmed..
Old Sep 30, 2003 | 06:12 PM
StorminMatt's Avatar
Default Re: Quick Question: 16valve=dx head? (skud_dusty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skud_dusty &raquo;</TD></TR><TR><TD CLASS="quote">isnt the HF an 8 valve motor?</TD></TR></TABLE>
Yes. But it was never available on an actual Civic. Only a CRX.
Old Sep 30, 2003 | 06:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">and i've "heard" of HF mini-me's.. but that is not yet confirmed..</TD></TR></TABLE>
It is entirely possible that someone may have Dremelled valve cutouts on HF pistons.
wubanga
Apr 13, 2009 05:55 PM
pinks11
10
Mar 16, 2009 03:52 AM
obd1_crx
Jun 12, 2007 05:32 PM
89efhatchy
Apr 29, 2007 08:17 PM
