Oil in spark plug holes? WTF?
Old Aug 26, 2001 | 01:58 AM
G2_Integ's Avatar
New User
Default Oil in spark plug holes? WTF?
When I went to change my spark plugs today, all the little cavaties in the block were filled with oil, up to the top of the spark plugs. I have no idea how it got in there. My spark plugs were easy enough to remove, but they didn't seem to be loose, certantly not loose enough that oil could get past the threads.
I should also mention that my car seems to be using a little oil lately... it doesn't seem to be burning any though (I can't see any smoke), and I can't find any leaks.
My car only has 75k miles on it and has always been maintained, so I don't know what's going on here... hopefully there is a reasonable explination for this & there isn't something seriously wrong with my engine...
Old Aug 26, 2001 | 02:01 AM
GZR4DR's Avatar
Default Re: Oil in spark plug holes? WTF? (G2 Integ)
There are 4 valve cover groments that go over the spark plug holes. Just pull your valve cover and replace the little gaskets. Easy fix.
Old Aug 26, 2001 | 09:01 AM
erasure2's Avatar
New User
4DR has it correct, that is most likely your problem. The grommets are abt $2.50 each from the dealership. When you install them do not use any silicone or gasket maker...this is not needed...it may cause a bad seal after a bit of driving.
Goodluck!
e2
Old Aug 26, 2001 | 10:54 AM
C-speed's Avatar
Default Re: Oil in spark plug holes? WTF? (erasure2)
They are called "tube seals". Order them from Honda
Old Aug 26, 2001 | 02:51 PM
G2_Integ's Avatar
New User
Thanks for the advice guys... hmm maybe this would be a good time to repaint my valve cover, anyone know where I can get factory Type-R red paint? Hehe...
Will I also need to replace my main valve cover gasket, or is it OK to reuse my old one?
[Modified by G2 Integ, 11:52 PM 8/26/2001]
Old Aug 26, 2001 | 03:35 PM
KL's Avatar
KL
New User
You can reused provided it wasn't leaking and it wasn't damaged during the removal, and that there's no cracks signaling impending failure.
pwrofdrm
Mar 29, 2023 06:50 AM
1998_4dr_gsr
Apr 13, 2011 09:02 AM
JDManuel
Feb 2, 2010 05:02 PM
fjt
Nov 23, 2004 08:52 AM
Doogie Howser
May 22, 2002 11:59 AM
