AVCR Gear dependant boost?
Old Sep 28, 2003 | 02:43 PM
Aeka GSR's Avatar
New User
Default AVCR Gear dependant boost?
How do I set up the Apexi AVCR to have gear dependant boost? I can't figure this out. I can select RPM boost all day long but I don't see anywhere to select gear boost. Many people have stated that this controller has gear dependant boost.
Old Sep 29, 2003 | 07:32 AM
Aeka GSR's Avatar
New User
Default Re: AVCR Gear dependant boost? (Aeka GSR)
nobody?
Old Sep 29, 2003 | 08:54 AM
inspyral's Avatar
This probably isn't much help to you, but from what I've heard and understand, gear dependent boost is pretty hard to set up, at least with Hondas. In fact, I don't think I've ever heard of anyone doing it successfully with the AVC-R, so most people just kinda forget about that feature. I'm sure there are ways to get it done, I've just never heard of anyone doing it with an AVC-R and a Honda
Old Sep 29, 2003 | 09:22 AM
Aeka GSR's Avatar
New User
Default Re: (inspyral)
dang, I just dont want to be boosting 12-15 lbs in first gear, ya know?
Old Sep 29, 2003 | 04:35 PM
superfuji57's Avatar
I don't really believe that. I'm not sure, but I think it has something to do with setting the mph for each gear or something? I forgot, but you have to have the AVC-R learn the gears.
Old Sep 29, 2003 | 05:57 PM
Mr.DC2TurBo's Avatar
Default Re: (Aeka GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aeka GSR &raquo;</TD></TR><TR><TD CLASS="quote">dang, I just dont want to be boosting 12-15 lbs in first gear, ya know?</TD></TR></TABLE>
How much boost u running?? I'm running 8lbs now and I don't even see that until I hit 2nd (probably bc i don't rev it that hi in first).
Old Sep 29, 2003 | 07:44 PM
Aeka GSR's Avatar
New User
Default Re: (Mr.DC2TurBo)
im currently running only 8-9, but im rebuilding for 15 or so.
Old Sep 30, 2003 | 12:08 AM
austrian type-R's Avatar
setting up the gear dependend boost level is the easiest thing on that controller IMO. I can not undersant how all the other 250+whp do not use this option. Just dial in
1st) -30%
2nd) - 15%
2rd) - 0%
If you want to run 30% lower booost than setted at all in first gear you have to do it like I shoed it. You also have to calculate with the AVCRs manual the gear speed setting. There is a lil forumla in the manual how to calculate it. It works so great and I could not drive my IR on the track at all w/o this option.
Old Sep 30, 2003 | 01:00 AM
Lei Siew Long's Avatar
Default Re: (austrian type-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">setting up the gear dependend boost level is the easiest thing on that controller IMO. I can not undersant how all the other 250+whp do not use this option. Just dial in
1st) -30%
2nd) - 15%
2rd) - 0%
If you want to run 30% lower booost than setted at all in first gear you have to do it like I shoed it. You also have to calculate with the AVCRs manual the gear speed setting. There is a lil forumla in the manual how to calculate it. It works so great and I could not drive my IR on the track at all w/o this option.</TD></TR></TABLE>
could you go into a little more detail with this because i don't understand how to use this feature as well.
thanks
Old Sep 30, 2003 | 06:20 AM
pissedoffsol's Avatar
2rd) - 0%
Damn y0! that kangaroo tranny you have owns!! j/p man haha
how to set it up is all in the manual...
http://www.apexi-usa.com/produ...s.pdf
bootlegcivic
Feb 18, 2005 05:00 PM
eghatchproject
Feb 21, 2004 04:57 PM
Hoosier Daddy
Dec 25, 2003 04:32 PM
ludelvr
Jun 24, 2002 12:31 AM
