HELPPP!!!!
i want to put ctr pistons in my b18c1 block....but i dont know what rods to use...if i use the stock ctr rods...and a oem head gasket, would the pistons hit the valves?....also im going to run either ITR cam or skunk 2 stage 2....would that also make a difference in the clearence?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">91 should be OK, just make sure you can get it tuned quickly.. Break the motor in on the dyno and tune it all in one fell swoop.. </TD></TR></TABLE>
it may be ok, but timing would so retarded, that you would probably be just as quick with less compression and more timing. i say 93 octane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">with the B16 head, you'll have about 12:1 compression, so you'll be OK with 91 OR 93</TD></TR></TABLE>
but why put 91 when u can put 93. less detonation
