Manuel transmission fluid... Which?
Old Aug 25, 2001 | 11:18 PM
976's Avatar
976
New User
Default Manuel transmission fluid... Which?
I am considering Redline 75w95 MTL. What have you heard? What's a good filter? Will I have enough space if to change fluid if car is on 2 foot lifts? Thanks.
[Modified by prsi, 8:20 AM 8/26/2001]
Old Aug 26, 2001 | 08:49 AM
HXMan's Avatar
Default Re: Manuel transmission fluid... Which? (prsi)
You can just jack the passanger side up a little, remove the front wheel, and you will have enough room to change the fluid.
I used Honda MTF.....works great. Tranny shifts perfect.
Old Aug 26, 2001 | 10:19 AM
kungfuSiR's Avatar
Default Re: Manuel transmission fluid... Which? (HXMan)
I have the Redline MTF and i'm impressed with it, however it is for more extreme driving, and does take some time to warm up. It is difficult to get it into certain gears when you're just driving around, but when you're at the track nothing is better
Old Aug 26, 2001 | 10:07 PM
therealnapster's Avatar
New User
Default Re: Manuel transmission fluid... Which? (kungfuSiR)
I used redline in before, it made my 3rd gear grind because the weight was too light. With fresh honda mtf is stopped skratching and feels smoother shifting too.
just my opinnion.
-Derek-
Afterdark
Old Aug 27, 2001 | 07:17 AM
BoM's Avatar
BoM
Default Re: Manuel transmission fluid... Which? (sohckid)
Old Aug 27, 2001 | 07:35 AM
coquinn's Avatar
I've only heard horror stories about Redline transmission fluids. I would recommend using Honda MTF or KAAZ Powertrain Gear Oil if you have a LSD. If you're dead-set on not using the Honda MTF, BG SyncroShift is an awesome transmission fluid as well ...most people are very impressed w/ the BG product; good luck.
Old Aug 27, 2001 | 08:15 AM
owen_the_soyboy's Avatar
OEM fluid is fine.
you should have the car level when you fill the tranny with fluid, otherwise you will not get the correct amount in the case.
to drain it... a 2 foot height is fine, mine was on a jackstand maybe 14 inches up all around.
Old Aug 27, 2001 | 10:13 AM
J28S's Avatar
New User
Default Re: Manuel transmission fluid... Which? (owen_the_soyboy)
I use Redline all throughout my car, and have never had a problem. When my trans was torn apart to put on a new clutch, I asked the chief mechanic to take a look at the transmission...I wanted to see if there was any wear. The guys at the shop even said it was very clean. I to had some grinding getting into third sometimes, but a new race clutch took care of that.
Old Aug 27, 2001 | 03:47 PM
Red Civic T's Avatar
New User
Default Re: Manuel transmission fluid... Which? (J28S)
Redline Shockproof Ultralite (70w0) - that stuff is good and generally thought to be a bit better than their MTL for Hondas see KGPrecision Engineering for ex...
Old Aug 27, 2001 | 06:48 PM
137's Avatar
137
Default Re: Manuel transmission fluid... Which? (coquinn)
ive been using mobil one gear oil, tranny is a lot smoother but still having problems getting into some gears immediately, the gear input shaft may have been damaged when my stock clutch blew.
Old Aug 28, 2001 | 11:30 AM
976's Avatar
976
New User
Default Re: Manuel transmission fluid... Which? (137)
Thanks for the all replys, very helpful!
owen_the_soyboy: I never thought about it like that, I would have just jacked my front, then it wouldn't be level, thanks!
I might just go with Honda MTF, later when new engine is in, I will switch to redline for the tracks...
CRP
Nov 5, 2017 01:06 PM
b18c1vtecdc2
Nov 14, 2008 09:02 AM
BB1 pOwA!!
Aug 24, 2007 11:03 PM
globy123
Dec 17, 2006 07:20 PM
civicmon
Aug 31, 2003 06:59 PM
